Old 12-20-2012, 11:40 AM   #1
Banky
Default No Engine Block Number, WHY?
Hi all, my block does not have a number punched into it? Drivers side, directly below the head. There's a spot for it, but no number?
SUPER RARE, worth a ton of $$$$$!!!
I will be entertaining offers over $100,000.
Assuming it's a replacement block?
thoughts?
thanks,
Banky
Banky is offline   Reply With Quote
Old 12-20-2012, 11:52 AM   #2
Rowdy
Default Re: No Engine Block Number, WHY?
Likely it is a replacement block. I have a couple of them that way. Just curiuos is it a diamond block bt chance? Not worth a ton as many of them are out there. Rod
Do the RIGHT thing - Support the H.A.M.B. Alliance!!!!
Rowdy is offline   Reply With Quote
Old 12-20-2012, 12:00 PM   #3
Steve Plucker
thoughts?
thanks,
Banky
If the number pad is as smooth as a babys butt, then more than likely it is a restamp...Look very closely, you just may see signs of numbers.
If it is as rough as the rest of the block, then Hmmmmm...Just how long is the number pad?
Pluck
Old 12-20-2012, 12:25 PM   #4
JD Miller
As mentioned the motor is a replacement. Many times these engines were not stamped by the dealer or repair shop that did an engine replacement. Not special, just not stamped. There are a lot of these engines out there. I've had several.
JD Miller is offline   Reply With Quote
Old 12-20-2012, 12:35 PM   #5
SLPreston53
SLPreston53's Avatar
I know someone who did a rebuild with a non-matching numbers block. Milled off the numbers then went over the boss with a descaler. One would be hard pressed to know that the block at one time had a number.
SLPreston53 is offline   Reply With Quote
Old 12-20-2012, 01:51 PM   #6
Rowdy
In states where the Model A engine number is considered the VIN that would be a felony. I won't say that it does not happen, but I would not make it public knowledge. Rod
Old 12-20-2012, 01:54 PM   #7
RonC
RonC's Avatar
I believe all factory assembled motors were stamped and only replacement bare blocks came unstamped.
RonC is offline   Reply With Quote
Old 12-20-2012, 03:09 PM   #8
Bruce Adams
Bruce Adams's Avatar
I have read on past Fordbarn posts that Sears Model A engines did not come with serial numbers.
I would assume that means engines rebuilt by Sears during that period.
Bruce Adams is offline   Reply With Quote
Old 12-20-2012, 04:04 PM   #9
oldmanandakid
oldmanandakid's Avatar
What is a diamond block?
oldmanandakid is offline   Reply With Quote
Old 12-20-2012, 06:32 PM   #10
msmaron
msmaron's Avatar
Send a message via AIM to msmaron
Not the Diamond Marks,, hence it was called the "Diamond Block" replacement model a blocks..
Mark Maron
Ill., Region MARC & MAFCA
MARC JSC Member MAFFI Trustee
National Facebook Admin.
https://www.facebook.com/groups/MARC.group/
A7191-Sport Coupe
29 Roadster
29-Town Sedan
29-Original Special Coupe
msmaron is offline   Reply With Quote
Old 12-20-2012, 06:43 PM   #11
Russ/40
Russ/40's Avatar
When I was a kid, some 50 years ago, I found an "A" engine in a field. I gave it to a friend who ended up running it in his 31 Sport Coup. When he went to register the vehicle, I ended up with the police knocking on our door. It was one of those blocks with no number.
Russ/40 is offline   Reply With Quote
Old 12-20-2012, 07:27 PM   #12
oldmanandakid
Thanks Mark............Jerry
Old 12-20-2012, 08:25 PM   #13
Banky
Not sure if it's a diamond block, I'll have to check. I'm in my jammies and my garage is cooooooooold! So it will be tomorrow. This is turing out to be an interesting thread though. At least it is for me. Thanks
Old 12-20-2012, 09:55 PM   #14
Fred K-OR
Fred K-OR's Avatar
When a person registers an A with the state and in that state the VIN number is the engine number and that person swaps engines, what does that person do?
Fred Kroon
1929 Std Coupe
1929 Huckster
Fred K-OR is offline   Reply With Quote
Old 12-20-2012, 11:18 PM   #15
Mike V. Florida
Mike V. Florida's Avatar
File new paperwork.
Old 12-20-2012, 11:34 PM   #16
Rowdy
By the way the law reads in this state, they are supposed to surrender their original title and apply for an assembled vehicle title. I have never heard of anyone doing this, but that is the way the law reads for any vehicle before 1948. The intentions of the law passed in 1987 was to help shut down chop shops in the Eastern part of the state and was also tied to a bumper height and fender law. All of which are widely ignored by law enforcement. Rod
Old 12-21-2012, 09:24 AM   #17
Richard Wilson
Richard Wilson's Avatar
Then there is the worst case. Older owner (80+) that has owned his Model A since the mid-40's and still drives it almost every day. Frame has been changed twice and engine changed at least eight times. Never has had a title change or DMV serial number inspection as long as he has owned it.
Richard Wilson is offline   Reply With Quote
Old 12-21-2012, 01:08 PM   #18
Special Coupe Frank
Special Coupe Frank's Avatar
His descendants will thank him when it comes time to settle the estate if the car is part of it...
Special Coupe Frank is offline   Reply With Quote
Old 12-21-2012, 01:09 PM   #19
Special Coupe Frank
Mark, is that photo up-side down ?
SC Frank
Old 12-21-2012, 01:23 PM   #20
28-31
28-31's Avatar
That's not good, but at least he's alive to write the affidavit and "try" to convince the appropriate authorities. The actual worst case is his descendants trying get everything straightened out (as already mentioned above) -- or, as is more often the case, the car changes hands several times, having had the frame and engine swapped-out over the years at least once -- with no one left alive to tell the tail.
It's a good time, let me tell ya...
28-31 is offline   Reply With Quote
