Old 07-29-2010, 07:36 AM   #1
PeteVS
PeteVS's Avatar
Default Painting chromed parts?
Anyone have any luck painting chromed parts? Sand blast to roughen up surfaces? Sand paper? I don't think there's any chemical that will remove chrome- is there? Thanks for any help here!
Don't never get rid of nuthin!
PeteVS is offline   Reply With Quote
Old 07-29-2010, 08:27 AM   #2
Poppa Joe
Default Re: Painting chromed parts?
After sanding you need to use an etch primer..or..2 pack..Etch..or polyurethane primer
Cheers
PJ
Poppa Joe is offline   Reply With Quote
Old 07-29-2010, 09:07 PM   #3
paul2748
paul2748's Avatar
You can have them stripped at a chrome shop - usually pretty cheap.
Old 07-29-2010, 09:20 PM   #4
PeteVS
PeteVS's Avatar
Any idea how they do it?
Old 07-29-2010, 09:37 PM   #5
coilover
They reverse the cathode and anode which dissolves the plating back into the solution.
coilover is offline   Reply With Quote
Old 07-29-2010, 09:46 PM   #6
PeteVS
PeteVS's Avatar
Makes sense! Thanks!
Old 07-29-2010, 10:07 PM   #7
Bassman/NZ
Bassman/NZ's Avatar
I think reverse plating leaves the copper on. At least the axle and split bones I had de-chromed came back with the copper still on, so I'm still gonna have to etch it. Cost me $20NZ (about $15US).
Bassman/NZ is offline   Reply With Quote
Old 07-29-2010, 11:32 PM   #8
TechNova
Sandblast it and primer it. Depending on the blast profile, you may be able to epoxy prime followed by color. FYI, you cannot go from etch directly to color.
Usually you need an aggressive blast to roughen up the chrome, don't need to remove it. The aggressive blast usually means you will have to use a surfacer primer to fill and then sand before paint.
I have done this many times over the last 25 or so years.
TechNova is offline   Reply With Quote
Old 07-30-2010, 06:26 AM   #9
47Merc
The main problem with sandblasting chrome prior to painting is that if the chrome is flaking and has rust under it, it will keep flaking after it is painted. Getting it stripped by the plating shop is the best way.
47Merc is offline   Reply With Quote
Old 07-30-2010, 07:42 PM   #10
TechNova
Obviously in any blasting operation you would remove flaking and rust.
