Old 07-28-2010, 08:46 PM   #1
PABob
PABob's Avatar
Default 5 speed drive shaft
When installing a 5 speed what are you using for a drive shaft,do you have one custom made to fit or do you have one cut down to fit? I'll be running a banjo rear with a open drive in a 40 tudor, thanks for the help.
Bob
PABob is offline   Reply With Quote
Old 07-28-2010, 09:10 PM   #2
Krylon32
Default Re: 5 speed drive shaft
I'd have a new one built. The salvage yards in this part of the country charge so much for a used one that by the time you do new joints, shorten and clean it you dam near have the price of a new on in it. I use The Driveline Shop in Springfield MO. They have always been more than fair with me.
Krylon32 is offline   Reply With Quote
Old 07-28-2010, 09:48 PM   #3
34flathead
34flathead's Avatar
Originally Posted by Krylon32 View Post
I have new one built. The salvage yards in this part of the country charge so much for a used one that by the time you do new joints, shorten and clean it you dam near have the price of a new on in it. I use The Driveline Shop in Springfield MO. They have always been more than fair with me.
i had one made in one day from a shop that dose nothing but drivelines for anything that need one.
rich
34flathead is offline   Reply With Quote
Old 07-28-2010, 09:55 PM   #4
BCCHOPIT
BCCHOPIT's Avatar
http://www.jalopyjournal.com/forum/s...d.php?t=256226
BCCHOPIT is offline   Reply With Quote
Old 07-29-2010, 08:17 AM   #5
flathead4rd
flathead4rd's Avatar
I had a new one made for about $ 100 at a drive shaft place in Detroit.
flathead4rd is offline   Reply With Quote
Old 07-29-2010, 05:08 PM   #6
Pete Fl/Wi
Pete Fl/Wi's Avatar
Find a drive shaft shop near you and talk with them first. They will tell you how to measure for length and what yokes would work best. It's not a big deal, but overall length measured at ride height is important. If you have the orginal Ford shaft bring it with you.
Pete
Pete Fl/Wi is offline   Reply With Quote
Old 07-29-2010, 09:10 PM   #7
NDFlathead
I went to a junk yard here in ND and got one of the correct length for $20.00. I had to use conversion U joints. Total cost less than $50.00.
NDFlathead is offline   Reply With Quote
