Old 07-28-2010, 06:37 PM   #1
wrndln
Default Color sanding PPG Concept
Does anyone know if there is a time limit for when PPG Concept that has been sprayed and then color sanded. I believe it get harder the long you wait to color sand it. The spec sheets donot really specify any timeframe, just how long you need to wait before color sanding, not a end time.
Old 07-28-2010, 06:42 PM   #2
Dave Pratt - IL
Default Re: Color sanding PPG Concept
I don't know how long you can wait but I have wet sanded it more than a year after it was sprayed.
Dave Pratt - IL is offline   Reply With Quote
Old 07-28-2010, 07:49 PM   #3
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
You are correct in there is no time limit and that it just gets harder as it ages.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 07-28-2010, 08:06 PM   #4
wrndln
Thanks Brent and Dave. That was what I was hoping was the case. I may not get to color sanding for a few weeks after spraying as I have a lot of other things to do.
