Old 11-27-2012, 07:23 PM   #1
1963turnerjohn
1963turnerjohn's Avatar
Default 1939 vs 1941 front bench
Can anyone tell me the difference in size for a 1939 vs a 1941 Ford split bench seat? And if anyone knows - if a 39 bench is fit in a 41 - is it too small in side to side width?
If I use the 39 bench - it will be upholstered with custom high grade vinyl - so no worries about original spec, though I do want it to look like it fits the cars interior ( and not look too small )
Thanks,
John
1963turnerjohn is offline   Reply With Quote
Old 11-28-2012, 01:08 AM   #2
ken ct
Default Re: 1939 vs 1941 front bench
I would say a 41 is slightly wider than a 39 seat as the bodys kept getting wider through the yrs.How much i dont know.Doughtful if the mount holes would line up from one to the the other!! ken ct.
ken ct is offline   Reply With Quote
Old 11-28-2012, 06:24 AM   #3
funrunr
funrunr's Avatar
John, If it would help, I'm in Belleville,MI. just down the road. I have a 40 bench in my car that you could take measurements off of. Or if you needed me to measure it at a certain spot I would. I believe these are the same size as 39.
Thank God
this is only a hobby!
funrunr is offline   Reply With Quote
Old 11-28-2012, 08:17 AM   #4
Sid the Maineiac
Sid the Maineiac's Avatar
I believe 39 and 40 would be the same dimensions.The 39 should fit no problem in a 41,as Ken says holes may need redrilling due to not lining up.
Sid the Maineiac is offline   Reply With Quote
Old 11-28-2012, 12:35 PM   #5
TJ
TJ's Avatar
The 41 seat is wider than the 39. The backrest cushions also have a different configuration. The 41 seat is the same as the 46-48 seat. They should be fairly easy to find.
