Old 11-26-2012, 05:01 AM   #1
47Merc
Default 46 - 48 Running Boards
I have just mounted the body of my 47 coupe back on the chassis and I am trying to install the running boards.
I have a set of Drake's running board rubber mounting blocks. (24 to the pack) but it has been quite a while since I pulled it all apart and I can't remember exactly how they were put together. (CRS I guess)
Can anyone tell me if the rubber mounts go between the running boards and the bottom of the sills? underneath the running boards? or both sides of the running boards or what?
There seems to be a big enough gap between the two side body mounts that are front and rear of the door to be able fit two of the new rubbers, maybe one each side of the running board but I'm not sure about that either.
Thanks a lot
47Merc is offline   Reply With Quote
Old 11-26-2012, 02:44 PM   #2
peewee2you
peewee2you's Avatar
Default Re: 46 - 48 Running Boards
Is this what you are looking for?
peewee2you is offline   Reply With Quote
Old 11-26-2012, 06:19 PM   #3
47Merc
Yes Peewee2you That is what I needed.
Thank you very much.
