#1 |
Is there a front and a back orientation on the beam of the axle, in other words does it matter which side of axle faces forward?
How tight are the perch bolt nuts tightened before lining up cotter pin? Thanks |
#2 |
You will find this thread helpful-
http://www.fordbarn.com/forum/showth...466#post505466 |
#3 |
Stock axle? There s/b numbers stamped on one end of the axle.....that s/b on the left(drivers side) is my understanding.
#4 |
Thanks, I set mine up with the numbers on the drivers side
#5 |
It makes no difference which side the numbers are on especially since many of the original axles have no numbers forged into them. An original axle is straight and symmetrical.
As for perch pin nut torque, try to get a minimum of 50 pounds of torque (while lining up the slot in the nut with the hole in the spring perch pin for the cotter pin). |
#6 |
On a dropped axle, the EE is stretched into a sort of drunken sprawl... |
#7 |
thanks everyone for the responses
#8 |
Having personally worked on several hundred ….. here is the deal.
You will probably find the lock pin will only go in from one side most of the time. I believe this is because of a bit of a bur that develops from the nut. If you simply clean the hole with a 9/16 drill bit … the pin will go in from either side and all will work just fine. Some people will insist the hole is tapered and or ………………………………........ The truth is the only taper involved here is on the lock pin itself. |
#9 |
My '32 axle had a letter U stamped in the front so I just put it back together the same way.
