Old 11-08-2012, 01:35 PM   #1
Dave in Petaluma
Dave in Petaluma's Avatar
Default New cast iron brake drum rubs on shoes
Recently I bought a pair of cast iron front drums when Mike's had a sale on them. These are the USA made drums (I think). They came with new hubs and lug studs installed, and I had them cut for a better surface and new shoes arced to fit.
On assembly I found I could not tighten the wheel bearings on one side without locking up the drum. Disassembly shows the drum to be rubbing on the outside edge of the shoes and backing plates.
As I see it, I have two options: cut the drum deeper on the inner surface or grind the edges of the shoes and backing plates. A third option occurs to me, though. Can I put shim behind the inner bearing to move the whole drum/hub assembly outward a bit? I was hoping to take a trip in the car tomorrow.
Dave in Petaluma is offline   Reply With Quote
Old 11-08-2012, 01:46 PM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: New cast iron brake drum rubs on shoes
Have you tried swaping the front drums side to side?
Old 11-08-2012, 01:50 PM   #3
Charlie Stephens
Option 4, call Mike's. Let us know how they handle the problem. It is his problem unless you are leaving something out. The real measure of a business in not if they make mistakes but how they handle them. Please post the results.
Charlie Stephens
Old 11-08-2012, 01:54 PM   #4
J Franklin
J Franklin's Avatar
Are the shoes centered and in plane with the drum?
Old 11-08-2012, 02:09 PM   #5
Dave in Petaluma
I haven't tried swapping the drums, but that is a good idea. The shoes are centered and in plane with the drum.
For now I've put the old drum back on that side, as I've got to go to work, but I'll post when I figure this out, and I thank you for your replies.
Old 11-08-2012, 04:42 PM   #6
wrndln
I had the same problem when I install new drums/hubs on the rear I bought from Mike's last winter. The fronts were OK as is. I ended up filing down the outer 1" to 1 1/2" of the brake shoes. After I went through the process two or three times, the drums tuned OK. I just used a large rasp to file a little off the ends. It may not have been precise but worked fine.
Rusty Nelson
Old 11-08-2012, 06:08 PM   #7
Ed Northrop
Ed Northrop's Avatar
I replaced my drums with cast iron drums and when I installed them they bottomed out on the brake shoe. I checked my original drums and the inside face was a 90 degree angle to brake shoe area. The cast iron drum was rounded I had to put them back on the lathe and cut that area out. This solved the problem. This was front and rear drums.
Ed Northrop is offline   Reply With Quote
Old 11-08-2012, 06:24 PM   #8
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
There are some bearings out there that don't seem to be as deep on the inner race and it allows the hub to ride in further. See if you can get a bearing number off that inner bearing and I will look to see if I have the number of a bearing that works.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 11-08-2012, 06:33 PM   #9
BRENT in 10-uh-C
See if it is a Timken 15118
BRENT in 10-uh-C
Old 11-08-2012, 06:36 PM   #10
peters180a/170b
peters180a/170b's Avatar
Thank you for posting the number...
peters180a/170b is offline   Reply With Quote
Old 11-08-2012, 07:44 PM   #11
Dave in Petaluma
The inner bearing is marked Koyo 15118, a Japanese brand purchased from my local bearing house a couple of years ago. The races were in the hubs when delivered.
Old 11-08-2012, 08:47 PM   #12
charlesea
charlesea's Avatar
If the drum is going in too far and scrubbing on the inside have you put in axle shims?
charlesea is offline   Reply With Quote
Old 11-08-2012, 08:53 PM   #13
CarlG
CarlG's Avatar
Unless I'm mistaken, that only works on the rear drums. Dave was asking about fronts.
Old 11-08-2012, 09:21 PM   #14
redmodelt
redmodelt's Avatar
Simple fix would be to put a bevel on the outer edge of the lining.
Old 11-08-2012, 09:36 PM   #15
Duffy1
Not trying to high jack this tread ,but has anyone had this problem with the drums and backing plate and shoes Snyder sells . Appreciate your input .
Duffy1 is offline   Reply With Quote
Old 11-09-2012, 07:47 AM   #16
Frank Miller
Frank Miller's Avatar
The old drum works but the new one does not. The first thing I would do is start measuring and figure out what is different. Then you know what needs to be fixed by how much.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound
Frank Miller is offline   Reply With Quote
Old 11-09-2012, 07:52 AM   #17
Cajun
I found a similar problem. I had to take off .020 from the new drum. It was not quite true (round). It appears that the new brake linings are thicker or the drum has a high spot.
Cajun is offline   Reply With Quote
Old 11-09-2012, 08:18 AM   #18
BRENT in 10-uh-C
When I measure a Timken bearing setting face down, the shoulder of the backside measures .825" deep. Does yours measure the same??
BRENT in 10-uh-C
Old 11-09-2012, 08:36 AM   #19
JBill
Mine are from Snyder's and I didn't have this problem.
JBill is offline   Reply With Quote
Old 11-09-2012, 08:43 AM   #20
V4F
V4F's Avatar
call mikes & get the correct bearings for the races .
V4f
V4F is offline   Reply With Quote
