Old 10-13-2012, 05:11 PM   #1
bobmc
Default Toe-in Adj. tool
It became very aparent to me today that my toe in needed better adjustment. After a day of enjoying the changing of the leaves on the back country roads in Westen PA I totaly shreaded a good tire.
When I put the front end together I attempted to check the toe-in with a wodden ruler. Thought It was close, I was wrong.
Any one have instructions on how to build a more accurate tool to measure the toe in?
Or If on could be purchashed?
I did a search and found nothing on the subject.
thanks
bobmc is offline   Reply With Quote
Old 10-13-2012, 05:32 PM   #2
160B
160B's Avatar
Default Re: Toe-in Adj. tool
Here are three photos of an alignment tool I built based on a design one of our club members came up with. Works great!!! I use masking tape on the tire and the edge of the tool. The ends of the alignment tool where it comes in contact with the tire are beveled so you get good contact with the tape on the tire. This is where I make my mesurement with a small scale.
hope this helps
160B is offline   Reply With Quote
Old 10-13-2012, 05:55 PM   #3
Randy in ca
Randy in ca's Avatar
There's a bunch of info in this thread:
https://fordbarn.com/forum/showthread.php?t=74237
Randy in ca is offline   Reply With Quote
Old 10-13-2012, 07:02 PM   #4
Jerry Parr WI
Jerry Parr WI's Avatar
The tool is called a "Duby Wheel Alignment Gauge." A Google search will get you several suppliers. Still made exactly like the the one in the Ford Service Bulletins. Price $70. to $100. depending on the supplier.
Jerry Parr WI is offline   Reply With Quote
Old 10-13-2012, 07:35 PM   #5
J Franklin
J Franklin's Avatar
I have used the Duby gauge and it worked great. Don't smoke a duby before using the Duby or everything gets messed up.
Old 10-13-2012, 07:48 PM   #6
zzlegend
zzlegend's Avatar
I use a flat style spring loaded curtain rod, With a seamstress cloth measuring tape that has a sticky back and attach that to the curtain rod. Easy to install in the front of the tires and read, and then place in the back and read. Is it high tech? Not really but gets it close enough for me. Just a thought.
zzlegend is offline   Reply With Quote
Old 10-13-2012, 08:11 PM   #7
J Franklin
J Franklin's Avatar
Toe at 1/16 +- 1/32, Close enough.
Old 10-13-2012, 08:21 PM   #8
DosCoupe
DosCoupe's Avatar
Recently, I asked some question about 1932 Ford front end specifications and got a lot of great answers. The local Ford garage dialed my front in at 1/2 degree - laser methodology. Tires are now wearing even and we track much better in a cross wind. Mine had too much tow out, with similar disatrous tread wear.
DosCoupe is offline   Reply With Quote
Old 10-13-2012, 09:17 PM   #9
1931 flamingo
1931 flamingo's Avatar
1/2 degree of what??
Paul in CT
Old 10-13-2012, 09:34 PM   #10
Marco Tahtaras
Marco Tahtaras's Avatar
thanks
Unless both tires wore equally (and similarly) you need far more than a toe-in adjustment! It sounds like you have a badly bent front axle.
http://www.abarnyard.com/
Marco Tahtaras is offline   Reply With Quote
Old 10-13-2012, 10:32 PM   #11
Gary WA
Gary WA's Avatar
thanks
NAPA Auto parts have them. Have stock number if needed.
www.whidbeymodelaclub.com
Old 10-14-2012, 10:07 AM   #12
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Someone recently posted that he pushes 2 straight pins into tire tread, measures between them, rolls car forward, and measures again! NOT BAD!
I think I read somewhere that the measuring point should be 11" above the floor. Saw a pic of some brand name, spring loaded toe in guage that goes between the tires, and it had 2 skinny 11" chains dangling, that guaged the proper height. Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 10-14-2012, 10:54 AM   #13
Blessyouboys
Blessyouboys's Avatar
It's six inches above the floor, not eleven.
http://abarnyard.com/workshop/align.htm
Blessyouboys is offline   Reply With Quote
Old 10-14-2012, 11:03 AM   #14
[email protected]
modela@aol.com's Avatar
Years ago we just used a 2 x 10 inch by 8 foot plank of lumber and some chalk marks on the tire and on the board. Jacked the front end up just enough to rotate the front tires and you would put the 2x10 plank in the front of the tire and chalk both tire and board. Then rotate the tire to the back direction and move the plank so you can line up the chalk marks. On guy using this method had put in finishing nails into drilled holes in the plank and used them with the center groove of the Firestone tires. Worked well for us to get good wear on the front tires.
While the front end is still jacked up you can also pull a tight string from the back of the back tire all the way up to the front end of the front tire. Move the steering wheel for best alignment. If one side has both tires touching the straight string on both sides of both tires you can then go to the other side of the car and do the same. It should be off but it will give you a visual on how much you maybe towed in or out...
We were not trying to be laser precise but it worked for us.
I also like to rotate the tires yearly in a X pattern RR to LF, etc...
modela@aol.com is offline   Reply With Quote
Old 10-14-2012, 11:21 AM   #15
BILL WILLIAMSON
Blessyouboys,
Thanks for the correction I just told the Dog to help me remember that! LOVE THAT DOG! Bill W.
Old 10-14-2012, 12:53 PM   #16
Marco Tahtaras
I think folks don't think to click on links that are posted. I put that page up 14 years ago and many have never seen it!
Old 10-14-2012, 07:59 PM   #17
marc hildebrant
marc hildebrant's Avatar
Marco,
I read your posting and found it very helpful when I adjusted toe-in.
Marc
marc hildebrant is offline   Reply With Quote
Old 10-14-2012, 08:55 PM   #18
Purdy Swoft
Purdy Swoft's Avatar
Snyders has the tool listed on page A-103 of their 2012 catalog. Part number A-3282 and the price is $27.95 it comes with instructions. this is the type that I use. I got mine in the ninties and I believe the price has gone up. Its still less expensive than having the toe in set at a shop, if you want to do the job yourself.
Old 10-14-2012, 10:04 PM   #19
jkeesey
jkeesey's Avatar
I have the same tool purdy mentioned. It works like a charm, and is easy to handle. A lot of the older styles are kinda heavy and cumbersome.
jkeesey is offline   Reply With Quote
Old 10-14-2012, 10:27 PM   #20
Gary WA
Gary WA's Avatar
NAPA Part no. 807-2000 Alignment Gage.
