Old 10-11-2012, 10:26 AM   #1
TD
TD's Avatar
Default zinc plug
any suggestions on the best way to remove the zinc plug at the top of a 29 steering column? Mine is really in there!
TD
TD is offline   Reply With Quote
Old 10-11-2012, 12:17 PM   #2
Bruce
Bruce's Avatar
Default Re: zinc plug
Slide a piece of conduit into the column from the bottom. I use a chunk of galvanized pipe that used to keep the sag out of the middle of my grandmother's clothesline. Bounce the column on the pipe. A piece of 2X keeps the noise down and protects your garage floor. You won't have to pogo it very long before the bushing will pop out.
Bruce is offline   Reply With Quote
Old 10-11-2012, 04:51 PM   #3
Great Lakes Greg
Great Lakes Greg's Avatar
I ran an axle shaft up from the bottom and gave it some whacks with a big hammer. Some have two little screws holding it in, others have a "v" notch.
Great Lakes Greg is offline   Reply With Quote
Old 10-11-2012, 05:11 PM   #4
TD
TD's Avatar
thanks loads - hoping to get a replacement at Hershey this weekend.
TD
