Old 10-04-2012, 09:22 AM   #1
KGS
KGS's Avatar
Default Flat 337 Lincoln in a '39 CVS
Over time, I've seen a number of references to the conversion from a Ford Flathead to a Lincoln 337 motor. There was an article in an old EFV8 Mag about a '39 CV sedan that was done in the early Fifties. Since I'm not really up to speed on photo attaching, I sent the pics to Vic Piano to add them to this thread. Hopefully he'll be able to do it. The car was owned by Ken Austin from Oregon and he ran the car at Bonneville. I wonder if Austin is still around. KGS
KGS is offline   Reply With Quote
Old 10-04-2012, 09:34 AM   #2
Vic Piano
Vic Piano's Avatar
Default Re: Flat 337 Lincoln in a '39 CVS
Hi Ken,
Here are the photos you sent to me. I have a 337 in our '49 Cosmo Convert, but I've never seen a 337 in an earlier Ford, that's cool. I'd sure like to have that "three pot" intake manifold.
Imagination is more important than knowledge.
Vic Piano is offline   Reply With Quote
Old 10-04-2012, 09:48 AM   #3
KGS
KGS's Avatar
That manifold apparently was a "homade", designed and built by Austin while attending OSU. KGS
Old 10-04-2012, 11:02 AM   #4
Bruce Lancaster
Austin...he was covered in one of the early small magazines while in school for a drag car with a completely homemade injection system on a Ford six. Injection was through a hole in the intake valve seat, pressure control had a lot of parts from an oil furnace!
More recently he has manufactured Ardun, 337, and Lincoln V-12 manifolds.
Bruce Lancaster is offline   Reply With Quote
Old 10-04-2012, 11:15 AM   #5
oldiron73
oldiron73's Avatar
Gotta like them 337's.
In the process of getting another one out of a 1950 F7 fire truck.
oldiron73 is offline   Reply With Quote
Old 10-04-2012, 08:07 PM   #6
Dale Fairfax
Given that 1952 was 60 years ago, there's a chance that he's not (with us anymore). Ken was probably about 20 when he built that first 337 tripower manifold and stuffed it all into that '39. That would put him around 80. He's had a website: KenAustin's Rodshop.com where all of his current products were shown but as I just moments ago tried it all I got was "Under construction". Try Googling and you'll get some neat stuff.
That article in HRM back in '52 has been an inspiration to me for all those years-that's why my '53 F-100 has a 337 in it.
Dale Fairfax is offline   Reply With Quote
Old 10-05-2012, 02:42 PM   #7
V12Bill
V12Bill's Avatar
In 1952 a 337 might have been a good idea, but today parts are hard to come by. The engine is also very heavy and will cause handling problems. A SBC will add more go without the weight and a warmed up flathead will do the same thing.
V12Bill is offline   Reply With Quote
Old 10-05-2012, 07:31 PM   #8
Dale Fairfax
But, if you did either of those (SBC or warmed up flathead), you wouldn't be able to say: "Yeah, it's a Ford Flathead alright, but it's the biggest one YOU ever saw".
Old 10-05-2012, 10:52 PM   #9
Ol' Ron
Ol' Ron's Avatar
You can bore them a 1/4 inch too. You do the math.
Old 10-06-2012, 07:02 AM   #10
KGS
KGS's Avatar
V12Bill and Dale make good points. However, I posted this because this car is not the all to common, run of the mill SBC in a Ford (you pick the year). What I liked about this article is that it is "real Hot Rodding" from a guy back in the day. Wouldn't it be cool if that car still existed today with that engine. The article states that Austin bought it back but without the 337 engine. I wonder what changes he made to the suspension to make the car roadable. Back then, he had to design and make his own parts to accomplish his goal. No CE or Fatman to provide the "stuff" he needed. As Bruce said, he went on to other projects and even started manufacturing for others. Good ole American know how and Free Enterprise at work. I did Google his name and came up with a man of 93 years of age in the Portland area. Might be him. Anyway, that would be a cool car to replicate. Ken
Old 10-06-2012, 09:05 AM   #11
rotorwrench
rotorwrench's Avatar
I would have figured he found or had a heavier front spring made up for the 39. That big engine would likely have really taxed the original spring made for an 85 hp V8. Heavier load rated tires would have helped too.
Old 10-06-2012, 09:17 AM   #12
Dale Fairfax
The caption under the first photo above indicates that he did just that.
Old 10-06-2012, 09:24 AM   #13
B-O-B
B-O-B's Avatar
[Story said the engine was mounted on truck engine pads & a 3/4 ton truck front spring was installed.
QUOTE=Bruce Lancaster;511035]Austin...he was covered in one of the early small magazines while in school for a drag car with a completely homemade injection system on a Ford six. Injection was through a hole in the intake valve seat, pressure control had a lot of parts from an oil furnace!
More recently he has manufactured Ardun, 337, and Lincoln V-12 manifolds.[/QUOTE]
B-O-B is offline   Reply With Quote
Old 10-06-2012, 10:42 PM   #14
Dee
Yes indeed, Ken Austin is still around. He has a Dental equipment company ( A-dec) and still supplies special manifolds. I just got another 4 barrel Lincoln V12 manifold from him and he's running one of his 3 carb manifolds on his Zephyr powered hot hot.
Dee is offline   Reply With Quote
Old 10-10-2012, 09:59 AM   #15
Dale Fairfax
Just saw an interesting thread over on the H.A.M.B. re Ken Austin. A guy who posts as "billjones" has created a site that consists of a virtual tour of Ken Austin's Museum/car collection. Not only confirms that he's still with us but showcases a collection of superb cars plus his product line which includes aftermarket heads and manifolds for 337s & Zephyr 12s.
Old 10-10-2012, 03:36 PM   #16
KGS
KGS's Avatar
Dale, I've poked around the HAMB but can't find the article. Can you post a link to it? Ken
Old 10-10-2012, 03:47 PM   #17
KGS
KGS's Avatar
Found it. Ken
http://www.jalopyjournal.com/forum/s...85#post8230885
Old 10-10-2012, 03:54 PM   #18
KGS
KGS's Avatar
Found it. Ken
And here's the virtual tour. A big thumbs up to billjones.
http://rhmpano.com/tours/kenaustincars/
Old 10-10-2012, 04:04 PM   #19
Vic Piano
Vic Piano's Avatar
That's a nice collection!
Old 10-10-2012, 04:28 PM   #20
KGS
KGS's Avatar
[QUOTE I'd sure like to have that "three pot" intake manifold. Vic. /QUOTE]
Vic, Here's your chance to get one as it appears he's still doing them. Ken
