Old 09-19-2012, 04:53 AM   #1
2935ford
2935ford's Avatar
Default 59A Flathead Water Pump Bolt Size?
Can someone please give me the size(s)/length/NC or NF/lock washer or not for the water pumps on a 59A flathead.
Thanks.
2935ford is offline   Reply With Quote
Old 09-19-2012, 08:36 AM   #2
G.M.
Default Re: 59A Flathead Water Pump Bolt Size?
I believe they are 3/8" course threads with lock washers. The Ford parts manual has the correct lengths. If I recall they are 7/8" which is an odd size. 1" is a standard size BUT longer bolts could bottom out and not pull the pump up tight against the gasket. Use grease on both sides of the gaskets not silicon or gasket sealant. G.M.
www.fordcollector.com
Old 09-19-2012, 08:52 AM   #3
2935ford
2935ford's Avatar
Yes, thank you. I just found out. 3/8 x 1 1/4" NC and use a stainless bolt/washer for the bottom hole.
Old 09-19-2012, 08:58 AM   #4
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
1-1/4 bolts might be a little long, you don't need more than 3/8 to 7/16 thread sticking out. Those holes are dead holes and you don't want the bolts to bottom out. Walt
Walt Dupont--Me. is offline   Reply With Quote
Old 09-19-2012, 09:31 AM   #5
2935ford
2935ford's Avatar
Thanks Walt. The outside boss on these pumps is thicker which requires a little longer bolt and not forgetting the lock washer.
I'll test them first before final lockdown.
Old 09-19-2012, 09:32 AM   #6
Ed Pitts
Ed Pitts's Avatar
I use 1 inch for the bottom two and 1 1/4 for the top two. No problems with them bottoming out. Ed
Ed Pitts is offline   Reply With Quote
Old 09-19-2012, 09:52 AM   #7
19Fordy
19Fordy's Avatar
Be sure and apply anti-seize compund to ALL the water pump bolts and don not overtighten them. 25 foot pound will be fine. That's what I have for the 8BA water pump bolts.
Old 09-19-2012, 10:17 AM   #8
2935ford
2935ford's Avatar
Yes, looks like the 1" and 1 1/4" are going to do the trick.
Yes, I knew about the anti seize...thanks.
Will the grease instead of RTV reak down the gasket eventually?
Old 09-19-2012, 10:57 AM   #9
G.M.
No the grease keeps the gasket from getting hard, sticking to the pumps and can be removed and reused if nessesary. Clean the old gasket off. G.M.
Old 09-19-2012, 11:13 AM   #10
2935ford
2935ford's Avatar
Cool trick....thanks.
Yup, cleaned all the old stuff off yesterday.
Old 09-19-2012, 12:11 PM   #11
trainguy
trainguy's Avatar
SS bolts are a good idea,esspecially for the bolt in the water inlet. I struggled with a bolt that the head was almost rust away. Had to use one of those sockets that grip on the flats[made for rounded off corners ]
trainguy is offline   Reply With Quote
Old 09-19-2012, 03:42 PM   #12
G.M.
Use 6 point sockets on the bolts and double check to make sure the lock washer don't drop off the bolt that's in the pump inlet. If dropped it will get picked up and jamb the impeller. One guy got one jambed and the pulley came loose. G.M.
Old 09-19-2012, 03:48 PM   #13
Walt Dupont--Me.
I just made a 1/4 thick plate to cover the water pump hole so I could pressure test cracked block. I greased the gasket real good on both sides when I removed the plate it fell right off and the gasket was perfect. Walt
Old 09-20-2012, 08:49 PM   #14
Harylufa
Harylufa's Avatar
Hi
Tomorrow I must assembly water pumps, as i rebuilt
my 59AB and I read this interesting post. What the best product to put in both size of the gasket? grease or silicone?
I have new water pump gaskets
Thank you
Hary
I love my Ford V8 1946!
Harylufa!
Harylufa is offline   Reply With Quote
Old 09-20-2012, 11:01 PM   #15
columbiA
Just grease both sides of the gasket.Dont use silicone as it may plug the small hole in pump that allows oil to drain down from valve chamber & lubricate pump bushing.
columbiA is offline   Reply With Quote
Old 09-21-2012, 08:01 AM   #16
Harylufa
Harylufa's Avatar
Columbia
Thank you I will do that
Hary
Harylufa!
Old 09-27-2012, 04:41 PM   #17
2935ford
2935ford's Avatar
Got them both on and used grease....all done and buttoned up!
Thanks all!
Old 07-15-2020, 05:57 PM   #18
Gusty59ab
Hello every body!
I Have installed a refurbished water pump in a 59ab with four stainlet steel fasteners but they seems to loose and the lock washers (grover ones) became flat.
I think that stainlet steel are not hard stress fasteners.
Another question: When you install a refurbished water pump is it necesary to run the engine with out water for a little 2 minutes in order to seat the seal?
Thanks!!
Gustavo from Argentina
Gusty59ab is offline   Reply With Quote
Old 07-15-2020, 07:23 PM   #19
Step-down
Step-down's Avatar
Does any one use anti-seize paste on the outlet bolt
"I can't cry as long as I know the Lord has risen "
Step-down is offline   Reply With Quote
Old 07-15-2020, 08:20 PM   #20
RalphM
RalphM's Avatar
Originally Posted by Gusty59ab View Post
Hello every body!
Thanks!!
I would not run it without coolant. If you have a good quality replacement water pump, it should not leak.
RalphM is offline   Reply With Quote
