Go Back   The Ford Barn > To The Editors > Questions & Suggestions
Old 09-11-2012, 02:48 PM   #1
midwestdeuce
midwestdeuce's Avatar
Default 1940 Coupe with 49 - 53 Flathead
Installed a 53 Mercury in our 40 Coupe........problem is the short distance between the front water outlets at the front of the heads and the radiator outlets. Other than flexpipes (ugly), can anyone recommend something that looks good (other than fabricating something)?
Thanks
I prefer dangerous freedom over peaceful slavery. Thomas Jefferson
midwestdeuce is offline   Reply With Quote
Old 09-11-2012, 04:08 PM   #2
Lanny
Lanny's Avatar
Default Re: 1940 Coupe with 49 - 53 Flathead
hi midwestdeuce,
Just a note to say, this section is for "Questions & Suggestions" to the Editor.
You should list your question in the "General Discussion" section here,
in the '32-'53 section, and hopefully some members will be able
to answer your question and help you..... good luck .
If mama ain't happy, ain't nobody happy.
But if daddy ain't happy...RUN
What I GOT DONE TODAY...
I got the rear-end put in the recliner, and
now I'm going to rest up & watch TV
Lanny is offline   Reply With Quote
