Old 09-02-2012, 04:04 PM   #1
carguy01
Default 55 ford engine and trans
Hello everyone, I have a dilema I am doing a 55 ford fairlane 2 dr. sedan
(club sedan) I have installed a fat man front clip complete and I"m wondering
if I have enough room to use a C-6 transmission without cutting the floor up
I also have an AOD which i understand is a little bigger than the C-4 but smaller than the C-6 any help would be appreciated. Thanks Carguy 01 I'm using either a 5.O. or a 289
carguy01 is offline   Reply With Quote
Old 09-02-2012, 04:18 PM   #2
The Master Cylinder
The Master Cylinder's Avatar
Default Re: 55 ford engine and trans
Your going to use a C-6 with a 289? Seems like overkill to me. I'd use the AOD because it will give you OD. But even the C-4 should be more than strong enough.
The Master Cylinder
Enjoying life at the beach in SoCal...
The Master Cylinder is offline   Reply With Quote
Old 09-02-2012, 04:53 PM   #3
ford1
the c-6 was basically a truck trans used behind the big ford engines, it eats up about 35 horse,aod up till around 1989 or 90 are all hydralic operated, no wires like the chevy aod trans
ford1 is offline   Reply With Quote
Old 09-03-2012, 02:53 AM   #4
JeffB2
JeffB2's Avatar
No problem fitting the AOD,I have a 302 and AOD in my '54 Customline no mods needed it will sit right on the stock trans crossmember use an ANCHOR 2253 mount about $10 at Autozone.Be sure and get the Lokar T.V. cable real easy to use.You will need a 164 tooth flexplate with a 28 oz. balance for the AOD give these guys a call http://www.kmjent.com/ prices are good.AOD's from 1980-93 are non computer the best donors are 1988-93's with the improved lube mods and valve body.
JeffB2 is offline   Reply With Quote
Old 09-03-2012, 05:38 AM   #5
carguy01
Thanks for the input everyone .but the question I asked was will the C6 fit without cutting up the floor? also thanks jeff for the mount #, you don't know what the application for it was? Thanks again for your help
Old 09-03-2012, 05:42 AM   #6
carguy01
The A.O.D. is out of a 86 or 87 is this going to be as easy as the 88-93 trans
thanks again for your help Carguy 01
Old 09-03-2012, 08:08 AM   #7
LOWRIDER
LOWRIDER's Avatar
I think I saw somewhere that the C6 was a tough fit in those cars but dont quote me on that. I would go with the AOD myself just because of the OD but its your car. Someone here must know if it fits.
Dan Kingman Az. 86409
LOWRIDER is offline   Reply With Quote
Old 09-03-2012, 08:11 AM   #8
streetdreams
Location: Howell, Michigan, USA, The Peoples Slightly Overspent Demodependancy of Michigan
If you use the 289 make sure it's a later block with 6 bolts for the bellhousing. Basically, a 1966.
streetdreams is offline   Reply With Quote
Old 09-03-2012, 07:28 PM   #9
JeffB2
JeffB2's Avatar
Just as EZ,you can upgrade your earlier AOD with the 1988-93 valve body for AOD info check out this site: www.clickclickracing.com
Old 09-05-2012, 03:35 AM   #10
JeffB2
JeffB2's Avatar
This is a C4 mount used for about 20 years, ANCHOR is available at Autozone & O'Reillys and Rock Auto and many more.
Old 09-08-2012, 07:37 PM   #11
carguy01
thank you all
