Old 09-02-2012, 09:59 AM   #1
Kirby1374
Kirby1374's Avatar
Default body mount blocks
Hey all, I have a 30 Tudor that needs new body mount blocks eventually. I am missing the back ones. Until I by a new set I was thinking of cutting my own to temporarily use.
What is the thickness of the blocks?
Kirby1374 is offline   Reply With Quote
Old 09-02-2012, 10:38 AM   #2
Kirby1374
Kirby1374's Avatar
Default Re: body mount blocks
Or maybe a better question; are all the blocks front to rear the same thickness?
Old 09-02-2012, 12:56 PM   #3
Randy in ca
Randy in ca's Avatar
The two rear blocks are taller than the others because they fit up inside the subframe rather than under the cross sills. I have some dimensional pictures of the ones used for 1928-29 I can send if you want - I'm pretty sure the 30-31 ones are the same except for their length - believe they were made longer in order to reduce cracking of the subframe. If nothing else this will bump your post up again and maybe someone else can add some info.
Randy in ca is offline   Reply With Quote
Old 09-02-2012, 01:09 PM   #4
Minn-Tex Lee
Minn-Tex Lee's Avatar
Just a thought--Buy the complete set now and use only what you need for now. Save the rest for when you complete the job. They are not that expensive.
Lee
Minn-Tex Lee is offline   Reply With Quote
Old 09-02-2012, 01:39 PM   #5
pcup
on my 30 tudor [unrestored orig] they meas. 1 7/8" high X 1 1/2 wide, length is just over the rear cross member.
pcup is offline   Reply With Quote
Old 09-02-2012, 04:12 PM   #6
ford1
i have a partial set, 6 of 10, i believe thay are what you need, $15 shipping included leave a message here if interested,
ford1 is offline   Reply With Quote
