Old 09-01-2012, 01:55 PM   #1
duffer
duffer's Avatar
Default marvel mystery oil
Does any body use Marvel mystery oil in there gas? Or anywhere else in there car? Any thoughts on this stuff good or bad?
thanks
bob
duffer is offline   Reply With Quote
Old 09-01-2012, 02:09 PM   #2
Ross/Kzoo
Ross/Kzoo's Avatar
Default Re: marvel mystery oil
Look for previous posts about MMO. I've used it and had great results.
Ross/Kzoo is offline   Reply With Quote
Old 09-01-2012, 02:24 PM   #3
Gary WA
Gary WA's Avatar
Every fill up Good stuff been around since 1923!!!
www.whidbeymodelaclub.com
Old 09-01-2012, 02:27 PM   #4
Ron/IA
I agree with those above, it is good stuff. Not only are you providing top end oil (valve stems and top combustion ring, but you now have a coating of oil inside you gas tank to help prevent rust.
Ron/IA
Ron/IA
1929 Fordor Steelback
Hawk A Model A Ford Club
http://hawkamodelaclub.org/
Ron/IA is offline   Reply With Quote
Old 09-01-2012, 02:29 PM   #5
ford1
i use 4 oz per 10 gal of fuel and 1 qt in the oil at oil change , i have a filter so i need 5 qts at every change i use 40w all year long in my 4 flathead v/8s, and heaven forbid, i change the oil every 5000 miles, for you guys that still have and read the owners manual that was given with the car when new that says change every 500 miles, i save $150 more on one oil change over what you spend in 5000 miles , i save 10 oil changes, it adds up , and yes i have over 45000 on one engine and several thousand on the others, AND no problems
ford1 is offline   Reply With Quote
Old 09-01-2012, 02:32 PM   #6
socalplanedoc
socalplanedoc's Avatar
I've encountered testimonials to the wonder cure that MMO creates in my years with hit-miss, antique car, and vintage plane groups. It wont hurt anything (other than a tiny hit on your wallet) but there's simply nothing more than anecdotal evidence that it has any direct benefit. Lots of guys swear by it and love to spin stories on how it fixed everything from stuck valves to scurvy - Just as many will tell you it's a waste of time. The reality is, if anything improved it's most likely from the increased attention the sick patient got.
BUT, if it makes you feel better to use it, well, feeling better is a good thing isnt it?
socalplanedoc is offline   Reply With Quote
Old 09-01-2012, 02:40 PM   #7
Huckster Dave
So turn the coin over and you have no proof that it doesn't help. I would say that the testimonial of several people with nothing to gain would be a great start at some kind of proof. being around since 23 suggest that must be some new fangled snake oil.
Huckster Dave is offline   Reply With Quote
Old 09-01-2012, 02:54 PM   #8
J Franklin
J Franklin's Avatar
When my engine was freshly rebuilt the valves would get noisy when it got hot, most likely valve to guide clearance. A shot of MMO in the carb while running instantly quieted them. If nothing else it is a good upper cylinder lube. It smells good too!
Old 09-01-2012, 03:38 PM   #9
Ross/Kzoo
Ross/Kzoo's Avatar
In my 31 Buick I had sticky valves and after MMO it smoothed it out. Seems more people swear by it than at it.
Old 09-01-2012, 03:47 PM   #10
duffer
duffer's Avatar
i'll agree with it smelling good .
Old 09-01-2012, 04:09 PM   #11
sconnors
sconnors's Avatar
I use it with every fill up (4oz for 10 gal) and when I change my oil, the first quart is MMO then regular oil. I've also used it over the years to free bolts, nuts, and anything that sticks. In the past I've pulled my plugs and squirted some down the cylinders, let it sit for a few days...works wonders.
sconnors is offline   Reply With Quote
Old 09-01-2012, 04:29 PM   #12
msmaron
msmaron's Avatar
4 oz EVERY fill up....18.4 MPG..thank you
A7191-Sport Coupe
29 Roadster
29-Town Sedan
29-Original Special Coupe
msmaron is offline   Reply With Quote
Old 09-01-2012, 04:49 PM   #13
Purdy Swoft
Purdy Swoft's Avatar
I use it in the gas and oil. It has a detergent effect and keeps the inside of the engine clean.
Old 09-01-2012, 05:00 PM   #14
peters180a/170b
peters180a/170b's Avatar
Before i put the "A' away i put some in the gas and let it coat the inside of the carb. And by using this stuff remember to clean off the spark plugs.
peters180a/170b is offline   Reply With Quote
Old 09-01-2012, 05:13 PM   #15
Bruce Adams
Bruce Adams's Avatar
I can't imagine someone NOT using MMO in their Model A gas tank at each fill up.
Bruce Adams is offline   Reply With Quote
Old 09-01-2012, 05:42 PM   #16
andrewsheldon
andrewsheldon's Avatar
MMO is good stuff I've used it in a siezed up chainsaw after we got flooded run like atop now. Great stuff I'll mix it in my Model A.
andrewsheldon is offline   Reply With Quote
Old 09-02-2012, 11:29 AM   #17
P.S.
Not sure if this is the cure or not, however...
I live on top of a ridge, and both roads down are fairly steep. Going down hill, the A is in second and using engine braking all the way. Used to be that the car would lunge now and then, maybe 5 times on the down hill as if one of the cylendars didn;t "inhale" enough on a stroke.
I started adding MMO tot he fuel and that almost totally stopped now. Maybe it freed up the valves a little? Maybe not.
I still have to richen the GAV 1/2 turn or so on the downhill to keep carb from popping though.
P.S. is offline   Reply With Quote
Old 09-02-2012, 12:36 PM   #18
Special Coupe Frank
Special Coupe Frank's Avatar
I don't think the stuff would still be around if it didn't have some merits...
I like to add it to the fuel-tank, particularly in L-head, and splash-lubricated engines, for additional upper-cylinder lubrication.
Also for engines that have been dormant for a long time....
I have wondered for years if the odor of MMO comes from the inclusion of oil of wintergreen, which has interesting solvent properties...
Special Coupe Frank is offline   Reply With Quote
Old 09-02-2012, 02:30 PM   #19
V4F
V4F's Avatar
i like it to keep the carbon off the pistons , valves , etc .................
V4f
V4F is offline   Reply With Quote
Old 09-02-2012, 02:36 PM   #20
Dodge
I always put a little in my antique cars gas tank with a fill up its supposed to help a little with the unleaded gas. A friend of my fathers has taken a teaspoon full every
day since the 1920's and claims it keeps him regular, he's in his mid 90's now and still
hitting on all cylinders..go figure one more use of the stuff.
Dodge is offline   Reply With Quote
