Old 07-17-2010, 08:23 PM   #1
wardkew
wardkew's Avatar
Default centering e-brake pads
I've just replaced the e-brake pads on my '31. One side is centered perfectly, but the other is off enough that even with the band fully retracted to the stop, the pad drags. How is that adjusted?
wardkew is offline   Reply With Quote
Old 07-17-2010, 09:42 PM   #2
Bubby Sharp in KY
Default Re: centering e-brake pads
Wardkew , Is it possible you have the wrong side toward the backing plate as there is a difference? Bubby Sharp in KY
Bubby Sharp in KY is offline   Reply With Quote
Old 07-17-2010, 11:03 PM   #3
wardkew
wardkew's Avatar
nope, checked that. It doesn't fit at all that way.
ken
Old 07-17-2010, 11:12 PM   #4
pat in Santa Cruz
pat in Santa Cruz's Avatar
is the metal band warped?
pat in Santa Cruz is offline   Reply With Quote
Old 07-17-2010, 11:45 PM   #5
Ron in Quincy
Ron in Quincy's Avatar
Find another shoe that the lining is good but worn. Some of the replacement lining is quite thick and if the emergency portion of the drum has not been turned it will not retract enough to clear the drum. OR:
replace the carrier and grind the stops shorter but equal on both sides, this will allow the shoe to retract furthur; I really don't like to correct the problem in this manner !!!!
Ron in Quincy is offline   Reply With Quote
Old 07-18-2010, 07:46 PM   #6
wardkew
wardkew's Avatar
Thanks guys.
