Old 08-27-2012, 12:57 PM   #1
kwisor
kwisor's Avatar
Default removing body tudor 1930
hello
i am removing the body from my 1930 tudor i have all the bolts off but two in middle from top it is a round head unbolts under neath do i have to knock out these bolts i can not get body to move
kevin
kwisor is offline   Reply With Quote
Old 08-27-2012, 06:39 PM   #2
ford1
Default Re: removing body tudor 1930
there are 5 body blocks with bolts thru them and one bolt near the fire wall, all need to be removed, the bolts thru the body blocks and body rails can get stuck over the year because of corosion, you may have to take a hammer and a punch maybe to drive them all the way out, they need to be out and in your hand before the body will come off, and some times the body and blocks and rubber pads may be stuck to each other and need to be pryed loose from the splash apron
ford1 is offline   Reply With Quote
