Old 08-14-2012, 10:47 AM   #1
Super88
Super88's Avatar
Question Tool Question
I'm getting ready to place an order which includes a head nut torque wrench adapter and was wondering if there is any difference in the ones sold by the various vendors.
Super88 is offline   Reply With Quote
Old 08-14-2012, 11:00 AM   #2
CarlG
CarlG's Avatar
Default Re: Tool Question
Get the Snap-On or Macs version. (Picture from the Ford Garage)
Old 08-14-2012, 11:15 AM   #3
Rowdy
I agree, nothing better than the Snap-On version. I have not tried the Macs version. Rod
Do the RIGHT thing - Support the H.A.M.B. Alliance!!!!
Rowdy is offline   Reply With Quote
Old 08-14-2012, 11:24 AM   #4
bettlesr
bettlesr's Avatar
I got mine from one of the Ford distributors. Had to grind the top of the socket end a little lower to clear my "B" distributor. Other than that it works great.
Dick
bettlesr is offline   Reply With Quote
Old 08-15-2012, 01:46 PM   #5
Super88
Super88's Avatar
The Snap-on version has been discontinued for quite a while and may take some doing to track one down. Anyone know the part # or description of the Mac Tools version? I'm having trouble locating it in their catalog.
Old 08-15-2012, 02:15 PM   #6
CarlG
CarlG's Avatar
I have a couple of the Macs versions at home, I'll look up the part number tonight. I think that it also has been discontinued, but both the Snap-On and Macs tools are available if you look in "all the right places".
Old 08-15-2012, 02:40 PM   #7
HoarseWhisperer
HoarseWhisperer's Avatar
http://www.snydersantiqueauto.com/4326
http://macsautoparts.com/model-a-for...0R3CHL1106038/
Synder's versions works fine:
I know a lot of things; I just can't remember them all.
1928 CCPU 82-A
1931 Roadster 40-B Dlx (Canadian)
HoarseWhisperer is offline   Reply With Quote
Old 08-15-2012, 02:42 PM   #8
30ccpickup
30ccpickup's Avatar
I’ll be the devil’s advocate, why? It takes less than 2 minutes to remove the distributor, and in fact, if you do not want your distributor to rust and lock into the head it is a good idea to remove it just for fun occasionally.
http://MODELABASICS.com/ How Things Work on a Model "A" Ford
Fordbarners, Feel free to use the pictures on my site to answer questions and create tutorials/tech articles.
30ccpickup is offline   Reply With Quote
Old 08-15-2012, 03:22 PM   #9
Bob C
I looked in a old MAC TOOL catalog and it shows S126 11/16" caster camber wrench, nothing
comes up on their web site for that number.
Bob
Old 08-15-2012, 04:17 PM   #10
Mitch//pa
[QUOTE=30ccpickup;479881]I’ll be the devil’s advocate, why? It takes less than 2 minutes to remove the distributor, and in fact, if you do not want your distributor to rust and lock into the head it is a good idea to remove it just for fun occasionally.[/QUOTe
but to remove the dist you need to remove the armored cable hold down and that defeats the purpose when torquing or retorquing the head
Old 08-15-2012, 05:28 PM   #11
Dave in MN
Dave in MN's Avatar
The head nut torque tool adapter from Snyders works well. It is shown on page A-116 of their current (2012) catalog. Good Day!
Part number: A-6064-T
Dave in MN is offline   Reply With Quote
Old 08-15-2012, 05:49 PM   #12
Bob C
The Snyder's one looks like they just cut a socket in half and welded the pieces
to a piece of U shaped metal.
Bob
Old 08-15-2012, 10:57 PM   #13
Ray in La Mesa
THis could be a fun project. Just head for the swap meet , buy the correct size box end wrench and a short extension for the torque wrench, cut bend, and weld them together. I must confess, I've got a bucket of old wrenches and an acelylene torch so it was fun.
Ray in La Mesa is offline   Reply With Quote
Old 08-16-2012, 07:23 PM   #14
Robert
Mike's A-Ford-able manufactures AND sells a good one...beefy and cheap.
Robert is offline   Reply With Quote
Old 08-16-2012, 07:24 PM   #15
columbiA
On both my "A",s I dont use the ign cable hold down clamp,so in 2 min you can have the dist out & in & no need for the adapter.
columbiA is offline   Reply With Quote
Old 08-19-2012, 10:55 AM   #16
Super88
Super88's Avatar
Thanks for all the responses. I have something in the works.
Old 08-19-2012, 11:37 AM   #17
ford31
ford31's Avatar
I used an open end claw foot on last one I torqued and did not slip
ford31 is offline   Reply With Quote
Old 08-19-2012, 11:56 AM   #18
Dick Deegan
Dick Deegan's Avatar
I agree with 30ccpickup. I also remove the distributor to torque #1 head nut. It is very quick to do. I do not use the armoured cable hold down on #8. #8 is a very sensitive bolt/nut to begin with and I do not like tampering with it after it is torqued.
Dick
Dick Deegan is offline   Reply With Quote
Old 08-19-2012, 12:47 PM   #19
Bob C
You will not get a true reading using a crows foot.
Bob
Old 08-19-2012, 01:05 PM   #20
Tom Wesenberg
Tom Wesenberg's Avatar
Bob
It should be very close if the crow foot is snapped on 90* the the beam of the torque wrench.
