Old 08-07-2012, 10:26 PM   #1
allen
allen's Avatar
Send a message via ICQ to allen
Default modern Points latest problem
Once upon a time I would change every distributor to modern point set up,
that has since stop.
If the rubbing block isn't wearing off the moisture is screwing up the points every time i let a motor set over a month I have to rub the point to get them to spark again,
Is there a decent set of points I can run or just take the time and go back to original thanks AL
allen is offline   Reply With Quote
