Old 07-12-2010, 09:24 PM   #1
Dave Pratt - IL
Default Carbon buildup in carburetor
A friend was telling me that he had to open the fuel adjusting valve several turns to get his car to run and that it would not idle. He thought there was a problem with the carburetor. He dropped off his carb for me to look at. I opened it up tonight and can not believe the amount of carbon buildup in it. It looks like the inside of a tailpipe. The idle, cap and main jets were all covered. After cleaning it up, I can find nothing else wrong with the carb. All the passages are now open and jets (original) are the correct size, float set right etc. What could cause this much carbon buildup?
Dave Pratt - IL is offline   Reply With Quote
Old 07-12-2010, 10:14 PM   #2
Kurt in NJ
Kurt in NJ's Avatar
Default Re: Carbon buildup in carburetor
Is it black carbon ---or is it a dark brown goo ---if i leave the gas on untill i get the car parked, then shut it off I have gotten a dark brown goo that has drooled down the jet, and clogged it up, it only started happening in the past 3 years to me, something in the "new" gasoline when it evaporates leaves it.
An exhaust leak blowing out soot --that getting sucked into the carb??
I have seen camshaft, and valve seating problems fill intakes with carbon
Old 07-12-2010, 10:22 PM   #3
Mike V. Florida
Mike V. Florida's Avatar
Location: Florida between Sarasota and TampaSouth Florida
That's my vote! Leak at the manifold muffler connection.
Old 07-12-2010, 11:21 PM   #4
Jim/GA
Jim/GA's Avatar
Look for a bad distributor cap. Sounds like cross-firing to me, blowing the charge back out of the intake valve. Might only happen with spark rod at one extreme end or the other.
Jim Cannon
Former MAFCA Technical Director
"Have a Model A day!"
Jim/GA is offline   Reply With Quote
Old 07-13-2010, 07:12 AM   #5
Dave Pratt - IL
It is as black as can be.
Old 07-13-2010, 10:22 PM   #6
ford1
the only way carbon can get into a carb is thru the intake valve , sticking open or burnt, run a compression check on all cylinders
ford1 is offline   Reply With Quote
Old 07-14-2010, 06:43 AM   #7
Bob A.
In addition to what Ford 1 stated, weak intake valve springs too. A vacuum gauge test would be a worthwhile test.(somewhere around two to seven inches fluctuation below normal indicates poor valve condition)
"Some Talk the Walk while others Walk the Walk"
Bob A. is offline   Reply With Quote
Old 07-14-2010, 07:50 AM   #8
Steve Wastler
Steve Wastler's Avatar
[QUOTE=Kurt in NJ;43785]Is it black carbon ---"I have gotten a dark brown goo that has drooled down the jet, and clogged it up, it only started happening in the past 3 years to me, something in the "new" gasoline when it evaporates leaves it."
Kurt,
I think you may find the 10% ethanol in the new unleaded is melting off some old carmelized gas in the tank and or gas lines.
The mail truck had sat for about 25 years with gas drying up in the tank. It was an almost hard molasses about a quarter inch thick over the entire bottom of the tank. I bought a couple of gallons of the E85 ethanol and poured in the tank. It works well to disolve the molasses, and doesn't need agitation.
I have added and drained 1 1/2 gallons let sit for a week and repeated twice, the molasses is just about gone and the tank is looking pretty good.
You may want to peer inside your tank, if you see any darkining on the bottom you may want to drain and give it a try. Just my two cents, It has worked for me.
Steve Wastler is offline   Reply With Quote
Old 07-14-2010, 08:10 AM   #9
Jack '29 Sport Coupe
Jack '29 Sport Coupe's Avatar
I dump an ounce of "Star*Tron" in each tank of gas. It's a product made by
Star Brite and is available at Walmart in the boating section. It keeps my tank
and carb clean as a whistle. You can download the MSDS information on the
website. JMHO
Jack
Cincinnati, Ohio
Jack '29 Sport Coupe is offline   Reply With Quote
