Go Back   The Ford Barn > The Swap Meet > Wanted > Early V8
Old 06-23-2012, 11:59 AM   #1
eric
Default 37-40 steering box
City: hudson
State: nh
looking for 1937-1940 ford car steering box. good useable condition. I already have a junk one. thanks, Eric [email protected] or 603-401-5320
eric is offline   Reply With Quote
Old 06-23-2012, 04:25 PM   #2
flthd31
flthd31's Avatar
Default Re: 37-40 steering box
Saw this on HAMB the other day and booked-marked it.
http://www.jalopyjournal.com/forum/s...=1940+steering
I did notice your post in the forum also and you stated that you were putting it in a 36 coupe.
I'm quite sure that you'll have to do some work on the mount as the bolt pattern for the box is slightly different but definitely worth the trouble to upgrade.
flthd31 is offline   Reply With Quote
Old 06-23-2012, 04:49 PM   #3
Barry WNY
If you have the junker, get the parts. I haven't had to do the worm but the taper bearings & cups, pitman bushings & seal as well as the shim/gasket pack. once you do it up right, you know what you have. I have a 37 box restored in my Av8, drives beautifully.
Barry WNY is offline   Reply With Quote
