Old 06-15-2012, 12:51 PM   #1
nellis003
nellis003's Avatar
Default Treadle Vac - compensating valve?
Hi all,
I just installed a Treadle-Vac power brake system into a '58 Edsel Citation that previously had manual brakes. The brakes are working - too well. You barely touch the pedal at low speeds and the car noses down badly, like the front brakes are grabbing way too hard.
Is there a check valve that the power brake system is supposed to have, or are the shoes maybe too soft for power brakes? The only components I changed were the master cylinder and the pedal setup. Should I have done anything else?
Thanks for any guidance.
Nick
nellis003 is offline   Reply With Quote
