Old 07-08-2010, 07:29 PM   #1
OoltewahSpeedShop
OoltewahSpeedShop's Avatar
Default Another stuck Flathead story....
I traded for this flathead engine that "Supposedly" had been sitting dry in a garage for years.... "It's stuck, but can't be bad" that was the story.
I've tried every old school trick in the book to get it free. Marvel Mystery, Kroil, PB Blaster, Coke, Pepsi, antifreeze, nothing worked. Won't budge!
Here's what we found tonight. Beware! It's not pretty.
Wonder why it was stuck? Sitting dry for years. Really? What they didn't tell me was, that it obviously sat under a drain spout for a few years before that. Either way, didn't see any cracks, and the cylinders don't look too bad believe it or not.
It did move a little bit, so it's soaking again. Wish me luck!
Later,
Kevin
OoltewahSpeedShop is offline   Reply With Quote
Old 07-08-2010, 08:25 PM   #2
Dennis/Arkansas
Dennis/Arkansas's Avatar
Default Re: Another stuck Flathead story....
Hey Kevin, here's wishing you luck! It already looks much better. Please keep us informed of your progress. Very encouraging that it has moved a lick. Dennis/Arkansas
Dennis/Arkansas is offline   Reply With Quote
Old 07-08-2010, 08:31 PM   #3
Brendan
Brendan's Avatar
one guy told me he put brake fluid in the cylinders and lit it on fire, he said that it burnt very slow
Brendan is offline   Reply With Quote
Old 07-08-2010, 09:05 PM   #4
redfor40
redfor40's Avatar
it looks like it cleaned up real good i got one on a engine stand and guy said it was no good i am going to get another opinion
redfor40 is offline   Reply With Quote
Old 07-08-2010, 09:55 PM   #5
OoltewahSpeedShop
Obviously all the "Remedies" to a stuck flathead worked on the gunk. It's still stuck though. In the valve guides as far as I can tell. Looks as though the bottom end is loose, but the valves are stuck.
Does that sound right?
Old 07-08-2010, 10:02 PM   #6
Joe KCMO
Joe KCMO's Avatar
Very possible. The valves could be rusted in the valve guides and stopping it from turning. As a matter of fact, that was my first guess before your last post.
Joe KCMO is offline   Reply With Quote
Old 07-08-2010, 10:20 PM   #7
Mike B
Those upper right two pics, is that just after tear down, or after you had something in the engine?
Mike B is offline   Reply With Quote
Old 07-09-2010, 12:01 AM   #8
52merc
52merc's Avatar
Later,
Kevin
i would put it into a 44 gal drum of diesel leave it soak for a couple of weeks
52merc is offline   Reply With Quote
Old 07-09-2010, 05:10 AM   #9
OoltewahSpeedShop
Yeah those pictures with the junk in the cylinders were taken as soon as the heads came off. The later pics were after I cleaned it up.
Old 07-09-2010, 07:45 AM   #10
Ross in East Texas
Ross in East Texas's Avatar
Send a message via AIM to Ross in East Texas
Here in Texas we have 55 gallon drums.
Ross Murphy
1939 Ford Standard Coupe
Ross in East Texas is offline   Reply With Quote
Old 07-09-2010, 09:00 AM   #11
Old Redneck
Old Redneck's Avatar
Send a message via AIM to Old Redneck Send a message via Yahoo to Old Redneck
When I bought my 39 Std. it had been sitting for several years like 15. The engine was stuck. When I got it home I took the spark plugs out and filled the cylinders with PB Blaster pent fluid. Then I put a new battery in and every time I walk by the car I would bump the starter. The third day the engine broke loose.I then drain the oil and it had water in the oil??? I then check the tourque and the right side was only 40 pounds. I put a new head gasket on that sside. Been driving the cat for two years with no problem.Just takes time to solve the problem.Might try a little heat since you have the heads off also.
Old Redneck is offline   Reply With Quote
Old 07-09-2010, 09:09 AM   #12
GreenMonster48
GreenMonster48's Avatar
And 10 gallon hats
GreenMonster48 is offline   Reply With Quote
Old 07-09-2010, 09:14 AM   #13
jdl
jdl's Avatar
Send a message via ICQ to jdl
Try acetone & atf 50-50 mix. it is the best penetrate. squirt valve guides and all often.
jdl is offline   Reply With Quote
Old 07-09-2010, 09:31 AM   #14
tintoptexan
tintoptexan's Avatar
Originally Posted by aussiesteve View Post
The US gallon is smaller than the imperial gallon,hence the difference
Found this to further complicate matters. (Slow day at work).
There are 55 gallons in a drum and 42 gallons (1 U.S. gallon = 3.78541178 liters) in a barrel (i.e., 1 barrel = 158.9872948 liters).
Originally there were 40 gallons to a barrel. However, that was changed in the mid-19th century to give a little extra so consumers wouldn't feel "cheated."
A little over 23 gallons of gasoline can be refined from a barrel of oil. Other products (jet fuel, lubricants, etc.) make up the rest.
The easy way to remember the number of gallons in a barrel of oil: There are 7 letters in gallons and 6 letters in barrel. 7X6=42 gallons.
42 US gallons.
Joe.
tintoptexan is offline   Reply With Quote
Old 07-09-2010, 10:25 AM   #15
Paul Selfe
Paul Selfe's Avatar
Later,
Kevin
The engine in my roadster came from the "boneyard", dragged it out from under a one ton telephone truck that had been setting on it's side for many years. I thought it would be just for parts, so my son and I knocked half the pistons out with a big sledge and a 2 in, piece of barstock. Some came out the bottom after we got the crank out. Some had water, and some were just badly corroded in place, it looked worse than your pics. I looked the block over, and it looked in good shape. I had it bored .060, skin cut the decks, and ground the crank. It's been running great in the roadster for going on 15 years now. There's most likely a lot of life still left in that engine of yours. Good luck and have fun! Paul Selfe.
Paul Selfe is offline   Reply With Quote
Old 07-09-2010, 12:04 PM   #16
flat 39
flat 39's Avatar
I had a similar piston in my 8BA. I soaked it for days and took a BFH to it abd beat the living snot out of it until it came out.
flat 39 is offline   Reply With Quote
Old 07-09-2010, 12:11 PM   #17
Russ/40
Russ/40's Avatar
Tilt the block so a deck is level. Degrease the bores as best as you can. Fill the bores with Phosphoric Acid. It will dissolve the rust. All the penetrants in the world will not dissolve rust.
Russ/40 is offline   Reply With Quote
Old 07-09-2010, 12:35 PM   #18
Django
Django's Avatar
What about vinegar?
Obsessed with all things 1936 Ford since birth... thanks Dad.
Django is offline   Reply With Quote
Old 07-09-2010, 03:59 PM   #19
52merc
52merc's Avatar
everything isbigger in texas !!!!!!!!!!!!!!!!!!!!! lol
Old 07-09-2010, 07:26 PM   #20
Zeke...PA
Zeke...PA's Avatar
Had the same problem and description when purchased, 6 of 8 pistons were broken into pieces getting out. Valves were worse, most were cut off at bottom, heads broken off and driven down and out. I cleaned and relieved block. Cleaned ports. Still to go to the machine shop to see if it will clean up at 3 5/16 as it was std. but pitted badly. Zeke
Zeke...PA is offline   Reply With Quote
