Old 06-04-2012, 02:20 PM   #1
jfrankhash
jfrankhash's Avatar
Default Tire Pressure
What tire pressure would you guys suggest for my 1930 CCPU? Operating above 5000 feet here in Montana, a few days in the 90's, but usually 70's and 80's for summer highs. Thanks, John
jfrankhash is offline   Reply With Quote
Old 06-04-2012, 02:24 PM   #2
newshirt
newshirt's Avatar
Default Re: Tire Pressure
I run 35 psi at 7,600' elevation.
Ray White
newshirt is offline   Reply With Quote
Old 06-04-2012, 02:34 PM   #3
John Butts in CT
John Butts in CT's Avatar
35 psi since 1967... as Ford prescribed. No worries.
John Butts in CT is offline   Reply With Quote
Old 06-04-2012, 04:38 PM   #4
Michael in Sedona
Michael in Sedona's Avatar
35 psi at 4500 feet here in Sedona. Hot weather in summer, cold in winter.
Michael in Sedona is offline   Reply With Quote
Old 06-04-2012, 07:36 PM   #5
glenn in camino
glenn in camino's Avatar
35 all around on my coupe,tudor & sport coupe. 35 on fronts and 40 on rears of my station wagon and deluxe delivery because they are heavy in the rear.
glenn in camino is offline   Reply With Quote
Old 06-04-2012, 08:24 PM   #6
Napa Skip
Napa Skip's Avatar
35 psi at 72 feet above sea level (elevation should not enter into consideration, inasmuch as I believe tire pressure is measured relative to the ambient atmospheric pressure - that is, as psig; pounds per square inch gauge - rather than psia; pounds per square inch absolute).
Skip Keyser
Napa Valley A's
Olympic Vintage Auto Club (1980-1982)
MARC of San Diego (1977-1978)
MAFCA (since 1978)
MARC (since 1977)
Model A owners belong in their Model A’s; Model A’s belong on the road.
Napa Skip is offline   Reply With Quote
Old 06-04-2012, 08:52 PM   #7
Fred K-OR
Fred K-OR's Avatar
Another 35 PSI here.
Fred Kroon
1929 Std Coupe
1929 Huckster
Fred K-OR is offline   Reply With Quote
Old 06-04-2012, 09:38 PM   #8
Pastor Bill
It is my understanding that the brand of the tire will dictate the tire pressure. When I bought my 29 Tudor it had new tires and I noticed the tube valve stem was projecting from one wheel on an angle. I read that some of the lower priced tires requires 55 psi. to prevent this.
That is what I keep on my tires and no problems. However, most tires recommend 35psi.
Pastor Bill is offline   Reply With Quote
Old 06-04-2012, 10:04 PM   #9
Napa Skip
Napa Skip's Avatar
55 psi! Wow! To paraphrase Paul Simon's Gospel; "[Drives] Me Like A Rock."
Skip Keyser
Napa Valley A's
MAFCA (since 1978)
MARC (since 1977)
Old 06-04-2012, 10:38 PM   #10
columbiA
Generaly,the only reason you see tire valve stems on an angle is because the stems were not positioned properly in the first place.35# is the correct pressure on all except the rears on some commercial body styles.55# is way to much & will only wear out the tires quicker & be rough rideing.
columbiA is offline   Reply With Quote
Old 06-04-2012, 10:39 PM   #11
1928Pickuppain
1928Pickuppain's Avatar
Because of atmospheric pressure being what it is at 5000 feet you fill it to the 35 psi at that level but it you drive down to say 2000 feet the outside presure is higher and will drop you tire pressure so you need to add more to bring it back up but if you drive back up to 5000 feet you need to let out some air to bring the inside pressure down to 35 psi like was if you drive from 5000 to 7400 feet. hope that makes sense
1928Pickuppain is offline   Reply With Quote
