#1 |
If you recall, I got my engine running in my 29RPU. After having run it with the carb that was running very rich several times trying to get a nice idle, it developed a bad clanking sound which accompanied a very rough running motor. It would run OK for awhile then run terrible with the noise that was there only when it ran poorly.
Well I pulled the motor and tore it down for inspection. The only thing I found that was suspect was a couple valves had a fair amount of carbon buildup on the stems. There was no galling anywhere. Since it was apart, I pulled the double nut lifters and replaced them with the single bolt type. I also honed the guides for the exhaust valves a little so they would be a little looser than the intakes, as the spec calls for the exhausts to be a little looser. Put it all back together and fired her up today with a properly setup carb. Ran it at high RPM to break in the new lifters, and she ran real nice. I'm thinking I should re-torque the head and cover the chassis, putting it aside to begin work on the body, resisting temptation to run until I can drive it. Some day....... Needless to say I'm feeling much better about things. Now the sheet metal. Thanks to those who gave me encouragement. |
#2 |
On my rebuilt engine the valves were a bit sticky so I added Marvel Mystery Oil in the tank and ran some straight through the intake manifold wiper fitting. I had to do this 2 or 3 times on different days but after that nothing is sticking now. Good luck on the rest of your restoration.
#3 |
I have used acetone in gas tanks to free sticky valves..about 10% ratio.
#4 |
Yeah, MM Oil is great stuff!
Jack
Cincinnati, Ohio |
#5 |
The reason I tore my engine down, was a pretty high dose of MMO in the fuel did not free up the problem.
#6 |
