05-14-2012, 08:47 AM | #1 |
Brake Lights
Finally got Ol' Blue, 30 Fordor, out of storage on Friday, and went to our Annual Inspection Day with the club on Saturday. The car failed the inspection because the brake lights would not come on. In checking the wiring, both tail lights work, (the signals come on) so the wiring and bulbs are ok there. My third brake light in the rear window works, so I assume the brake switch is doing its job as well. My question is, could there be something wrong in the signal switch, that would stop the lights from working? The wire comes off the brake light switch, and goes into the signal body, and then back to the tail lights. Has anyone had a similar problem? Thanks for any help.... Jim
05-14-2012, 09:11 AM | #2 | |
Re: Brake Lights
This is the prime reason I would keep the signals a seperate system and wiring harness from the factory lights. I think problems are less likely, and if a problem comes up, it's easier to check if it's a seperate system. |
05-14-2012, 12:49 PM | #3 |
Re: Brake Lights
Thanks Tom, I suspected that.
05-14-2012, 01:33 PM | #4 |
Re: Brake Lights
i use hand signals , never interferes with any thing ........... sorry it just came out !
V4f |
05-14-2012, 04:23 PM | #5 |
Re: Brake Lights
05-15-2012, 06:05 AM | #6 |
Re: Brake Lights
