Old 05-06-2012, 10:37 PM   #1
NDFlathead
Default ?? installing lower door seals 34' 5 window
I have a stock '34 5 window coupe and in the process of installing the lower doors seals.
I'm thinking the side that has the 1/4" lip faces in toward the interior of the car and the bottom of the door panel will rest on the lip. Is this correct?
Any advice on how to trim the sides for the best fit and seal?
THANKS.
NDFlathead
NDFlathead is offline   Reply With Quote
Old 05-07-2012, 12:19 AM   #2
FlatheadTed
FlatheadTed's Avatar
Default Re: ?? installing lower door seals 34' 5 window
I would say its the same as 35 ,The lip goes to the out ,side sits under the door to stiffen it
http://www.flatheadted.com
Flathead Ted brake Floaters ,
