Old 04-16-2012, 11:56 AM   #1
Roadster Rich
Roadster Rich's Avatar
Default 6 Volt Batteries
Any recommendations on using a more standard 6 volt group 1 battery or paying a premium for the Optima type 6 volt battery for our A's?
Roadster Rich is offline   Reply With Quote
Old 04-16-2012, 12:29 PM   #2
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default Re: 6 Volt Batteries
Depends on your useage IMO. I have a 6v Optima in my daughter's Model T speedster and since the summer of 2007 it has been going strong will long periods of the vehicle not running.
Just the other day I went out and started the engine which had been setting since the Christmas parade last Winter without any charging or boosting. They are a superior battery due to technology but with that comes a price. From a long distance side-view glancing under the car, they are painfully obvious on a Model A. The next downside is the price of the battery and necessary hardware to hold it into the battery support carrier. If you use your car with frequency and are a good steward to your vehicle's battery (using a battery tender and keeping a constant check on the electrolyte level) & charging system, the regular type of battery will give good service too.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 04-16-2012, 12:47 PM   #3
28 Special Coupe
28 Special Coupe's Avatar
I bought a group 1 battery from O'Reilly Auto Parts a few years ago and have been perfectly happy with it. I just started up my Model A a few weeks ago after sitting dormant since early December and had no problems whatsoever.
Although the Optima is superior technology, it's way more expensive. The group 1 would probably suit you just fine.
28 Special Coupe is offline   Reply With Quote
Old 04-16-2012, 03:53 PM   #4
Roadster Rich
Thanks for the advice. I think that I will go for another standard battery based on what you have experienced. Important is the tender, and I have not had that in use as a rule. Probably why this battery only made it three years or less.
Old 04-16-2012, 04:33 PM   #5
Bruce Adams
Bruce Adams's Avatar
My six year old Optima is SUCH a trooper.
Its great to return after leaving the lights on or starting it a zero degrees, F or whatever, and seeing no effect on the battery. The horn appears to work better with the engine off, too, I guess its because the Optima keeps its full charge.
Yes, I guess it cost at least twice as much as a normally flooded Group 1 battery.
Bruce Adams is offline   Reply With Quote
Old 04-16-2012, 04:58 PM   #6
29ModelA
29ModelA's Avatar
I had HORRIBLE luck with the 12V Optima's in my jeeps, enough so that I will not touch one for our Model A with a 10' pole.
I have a $70 Exide from TSC.
1929 Model A Barn find. California car, just a few more parts to find.
Interior, steering box (rebuild), and I am sure much more!
29ModelA is offline   Reply With Quote
Old 04-16-2012, 05:23 PM   #7
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Brent,
On Optima looking "funny," a friend lined his battery carrier with grooved stairtread rubber, looked lik a REAL battery at a glance. B.W.
"THE ASSISTANT GURU OF STUFF"
Old 04-16-2012, 07:18 PM   #8
ryan1929
ryan1929's Avatar
OPTIMA 6 VOLT Batteries are the best! Henry ford would approve...
ryan1929 is offline   Reply With Quote
Old 04-16-2012, 10:02 PM   #9
BILL WILLIAMSON
Whew!! I'm glad you cleared that with Hank, as I bought one awhile back. What else did he have to say?? Bill W.
Old 04-16-2012, 10:46 PM   #10
eagle
eagle's Avatar
ANY battery needs to be taken care of. The Optima are tough but will sulfate too if left dead or low for a period of time. I know an auto parts store owner who only recommends the Optima for use on squad cars/ambulances/etc due to the heavy current drain and large charging alternators. Otherwise, he doesn't feel they are worth the cost.
eagle is offline   Reply With Quote
Old 04-16-2012, 11:00 PM   #11
Kurt in NJ
Kurt in NJ's Avatar
I have had long life with both regular batterys, and the Optima, the Optima is 14 years and still going, the regular batterys I got 7, & 9 years out of them, 5 years from one off a "junk" pile ---all except for the original tar top repro script battery---it struggled to get 3 years ---
I have never used a battery tender, the generator has been enough to keep my batterys charged.
Old 04-16-2012, 11:03 PM   #12
Mike V. Florida
Mike V. Florida's Avatar
Location: Florida between Sarasota and TampaSouth Florida
From what I can find, 6v group 1 batteries are found by the following numbers;
NAPA - BAT 7244
Exide - 7200
Tractor supply - Com 1 HP (part number 0470506) I think.
Autozone - 1-6 volt
Old 04-17-2012, 01:41 AM   #13
Dodge
I had one "Miracle" battery that I bought at a Chevron station, I kept it on a battery
tender used only distilled water in it and some mubo jumbo battery stuff from
J.C. Whitney call VX-6 or something that I put in from new.
The battery lasted for 18yrs. before I ruined it by putting on a non-automatic charger
and went home for the night and forgot about.
It boiled the battery and ruined it.
Never got more that 5-6 yrs. out of any other battery since then.
Dodge is offline   Reply With Quote
