Old 04-16-2012, 08:59 AM   #1
MrTube
MrTube's Avatar
Default adjustable wrenches
While I realize an adjustable wrench isn't really the best tool I have a few on hand as they come in useful from time to time.
What is the difference between autolocking and standard? Does the autolocking feature have any drawbacks?
MrTube is offline   Reply With Quote
Old 04-16-2012, 09:10 AM   #2
marc hildebrant
marc hildebrant's Avatar
Default Re: adjustable wrenches
Is that question for a Metric or English wrench ????
Marc
marc hildebrant is offline   Reply With Quote
Old 04-16-2012, 09:12 AM   #3
MrTube
MrTube's Avatar
Both?
I guess the autolocking somehow locks the adjustment from spinning while in use.
One like this :
http://www.buy.com/prod/click-stop-p...219434138.html
Old 04-16-2012, 09:50 AM   #4
Aok
Aok's Avatar
I looked at the ad it looks like a standard adjustable. Never used a pronto so can't speak for the quality which even in adjustable wrenches makes a difference.
Aok is offline   Reply With Quote
Old 04-16-2012, 09:56 AM   #5
Dana Barlow
Wink Re: adjustable wrenches
Don't know how many types are out there,but ,
On the lock one I have=the barrel has small groves on the one end too lock it in place,to unlock and adjust you move it off the groves. The is a right and wrong way to use any adjustibles,the moving side of jaws should always be behind the force so load in at the bottom of moving jaw nearist the barrel vs at the top were there is more play in adjusted size.
Dana Barlow is offline   Reply With Quote
Old 04-16-2012, 09:56 AM   #6
MrTube
MrTube's Avatar
Yea, I don't know.
What I'm actually looking at is the same style but from Mcmaster so I have no idea what brand it would actually be. Mcmaster while pricey usually carries good stuff.
They give an option for standard or auto-locking. Autolocking sounds like it would be a good thing, just not sure if it would end up causing problems.
Old 04-16-2012, 11:32 AM   #7
VWJoe
VWJoe's Avatar
Does it come with a box of Band-Aids ??? Mine didn't.
VWJoe is offline   Reply With Quote
Old 04-16-2012, 11:52 AM   #8
CarlG
CarlG's Avatar
Proto tools are typically a cut above what you find retail, usually sold in an industrial invironment. I use to purchase a lot of Proto tools when I worked for a Shipyard. I'd say the quality is equivelant to Snap-On, Macs, etc.
Old 04-16-2012, 03:24 PM   #9
ctlikon0712
ctlikon0712's Avatar
I agree with CarlG, Proto is a top brand.
Wanted: Simmons Super Power Head
Craig Likon 1931 150B
ctlikon0712 is offline   Reply With Quote
