Old 04-10-2012, 02:49 PM   #1
35 coupe
35 coupe's Avatar
Default Hydraulic brake conversion for 35
What s the best hydraulic brake conversion to put on a stock 35 coupe, either aftermarket or other year ford that will fit. Do you have to change spindles? THANKS
35 coupe is offline   Reply With Quote
Old 04-10-2012, 06:04 PM   #2
2935ford
2935ford's Avatar
Default Re: Hydraulic brake conversion for 35
I did a '35 sedan using ECI front disc coversion w/5 on 5.5 bolt pattern.....real simple but I had a 9" out back w/drum good combo.
I first did the Buick fin drum conversion......nowhere near as good or simple as the ECI kit.
2935ford is offline   Reply With Quote
Old 04-10-2012, 06:57 PM   #3
Straightpipes
Straightpipes's Avatar
Mine has a 39 pedal assembly in it.
Straightpipes is offline   Reply With Quote
Old 04-10-2012, 07:28 PM   #4
Brad
give Richard a call at Early v8 Garage 626-338-2282
Brad is offline   Reply With Quote
Old 04-10-2012, 10:23 PM   #5
Ol' Ron
Ol' Ron's Avatar
If you;re looking for Cheep 40-48 ford
Old 04-10-2012, 10:51 PM   #6
B-O-B
B-O-B's Avatar
I have 40s on my 34 5/w
B-O-B is offline   Reply With Quote
Old 04-10-2012, 10:53 PM   #7
Charlie Stephens
Ron is right, but still call Richard Lacy for the adapter to use your original pedals and a hydraulic master cylinder.
Charlie Stephens
Old 04-11-2012, 07:49 AM   #8
JM 35 Sedan
JM 35 Sedan's Avatar
I'm actually pretty darn happy with my finely tuned and maintained mechanicals on my stock/original '35 fordor. Now, if I really wanted an improved hydraulic braking system I would leap frog the '39 to '48 Ford system and go directly for the repro Lincoln system combined with Richard Lacy's kit that uses the stock '35 brake pedals. His system eliminates the need to convert to a '39 clutch/brake pedal assembly that would also require a hole to be cut in the floor pan to fill/refill the MC. JMHO
John
Old 04-11-2012, 11:49 AM   #9
Richard (EV8G)
Richard (EV8G)'s Avatar
Thanks to all for the nice recommendations, and especially for spelling my name correctly!!! My son Dennis, who does most of the hard work, also thanks you...
Early V8 Garage
Pasadena Roadster Club
Richard (EV8G) is offline   Reply With Quote
Old 04-12-2012, 08:53 AM   #10
toddle321
toddle321's Avatar
I have Richard's kit on my both my '36 Cabriolet and Woodie, easy to install and works perfectly.
toddle321 is offline   Reply With Quote
