Old 03-30-2012, 03:57 PM   #1
Randy
Randy's Avatar
Default 6v to 12v, can I use my old starter solenoid?
I'm changing from 6v to 12v and want to know if I can use my old '40-style starter solenoid? It's the metal type with the button on it and it grounds through a button on the dash. Thanks!
Randy is offline   Reply With Quote
Old 03-30-2012, 04:08 PM   #2
Kahuna
Kahuna's Avatar
Default Re: 6v to 12v, can I use my old starter solenoid?
It will work fine. Mine has been working good for the last 22 years on my 39 coupe
Kahuna is offline   Reply With Quote
Old 03-30-2012, 04:09 PM   #3
G.M.
If your car starts on the first revolution yes but if it cranks to start the coil in the solenoid will get hot and burn out. Best to change it to a 12 volt solenoid but why change to 12 volts, 6 works just fine for me and a lot of others? G.M.
www.fordcollector.com
Old 03-30-2012, 05:38 PM   #4
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
I'd recomed 12 selonoid, I 've had a couple of 6 volt one stick while thay were cranking and had to rush around and unhook the batt for it to stop cranking. Scarry. Walt
Walt Dupont--Me. is offline   Reply With Quote
Old 03-30-2012, 09:27 PM   #5
Karl Wolf
Karl Wolf's Avatar
Seven years...
Still testing mine, I'll keep you informed....
Karl
Karl Wolf is offline   Reply With Quote
Old 03-31-2012, 11:46 AM   #6
mike in las vegas
mike in las vegas's Avatar
Two years and mine has been fine. By the way, where do you find a 12 volt solenoid that will work with the grounding principle of the starter button?
mike in las vegas is offline   Reply With Quote
Old 03-31-2012, 01:55 PM   #7
Karl Wolf
Karl Wolf's Avatar
You could use a relay to make it a ground acuated solonoid... I have a few 40 amp VW relays that I use for stuff like this...
Karl
Old 03-31-2012, 04:44 PM   #8
jack orchard
Karl
or you could replace the button with a isolated contact button (Neither contact is grounded) and run 12V thru it. or you sould use an isolated coil solenoid that could be activated by a ground...jack
Proud FNG
We fixem cars. Heap Good!
jack orchard is offline   Reply With Quote
Old 03-31-2012, 06:25 PM   #9
Junkyard Dog
Junkyard Dog's Avatar
go to napa and ask for a st56 selonoid
Junkyard Dog is offline   Reply With Quote
Old 03-31-2012, 07:02 PM   #10
Flat Ernie
Flat Ernie's Avatar
You'd have to crank for quite a while to burn it up...
They're for tractors or something, but they're available - not as readily available as a regular 12V starter relay.
Karl
You certainly don't need 40A to hold the starting relay!! But there's no kill like overkill, I suppose.
What's the application?
I've run all of my 12V cars on the original 6V starter relays - no re-wiring of the car required. They've lasted quite a while. I have had them stick once or twice, but a quick rap with a hammer or other heavy object, typically does the trick.
Daddy always said, "If yer gonna be dumb, you gotta be tough" and I'm one tough sumbitch!
T5 Tech
Flat Ernie is offline   Reply With Quote
Old 04-02-2012, 09:54 AM   #11
mike in las vegas
Great answers, Thanks gentlemen!
