Old 03-28-2012, 09:32 PM   #1
bobj49f2
bobj49f2's Avatar
Default Stuck/unstuck flat head
I have a EAB flattie that I was told came out of '53 car. Narrow pulleys.
The engine sat in a garage for over 20 years and when I found it it was laying on it's side. The was one spark plug and four broken ones on the driver's side and none on the passenger side. I got it home and removed the one complete spark plug, heat the broken ones and use an easy out. The all came out very easily, the broken ones even had the electron attached.
The engine would only move about 10° either way. I didn't want to wreck anything so after dumping penetrating oil in the cylinders and waiting a couple of weeks I pulled the heads off to check out the condition of the engine expecting to see a real mess. Other than the exhaust valves being a bit burnt and coated with carbon the insides look great, very little ridge at the top of the cylinders. I did have 4-5 stuck valves but with a little work and penetrating oil I got them freed up.
Here's my question. As I stated the engine would only move about 10° either way. I took the heads off and tried to spin the engine with a breaker bar on the pulley and the engine turned over and now turns very easily. What would have prevented it from turning before I removed the heads? I couldn't find anything that would have prevented a valve from opening. Any ideas?
Oh yeah, another strange thing, at least I thought, the passenger side head, the one without any spark plugs has a crack on the outside, just below the spark plug hold second from the front. Isn't this kind of a strange place to have a crack? I looked the block over really close with the help of a bright light and couldn't find any cracks in the block. There might be a hair line crack that I can't see with a naked eye but from close inspection I couldn't find any.
bobj49f2 is offline   Reply With Quote
Old 03-28-2012, 09:53 PM   #2
G.M.
Default Re: Stuck/unstuck flat head
The valve get a thin film of a white resin on the stems and stick. Marvel Mystery oil has freed a lot of them for me. Maybe the block was drained and the engine laying over with the passenger side down and enough water was in that spot to freeze and crack the head. There was one on here a week ago that cracked down near the pan rails. G.M.
www.fordcollector.com
Old 03-28-2012, 10:22 PM   #3
flatjack9
flatjack9's Avatar
Those 4 - 5 stuck valves are what kept it from turning.
Old 03-28-2012, 10:49 PM   #4
ford1
did you notice any marks on the head, valves or pistons, like maybe they were hitting there? removing the heads would clear the obstruction which was stopping the engine from turning. properly adjusted valves will not stop engine from turning even if stuck open unless the head has been over milled and letting the valves or pistons to hit it
ford1 is offline   Reply With Quote
Old 03-28-2012, 10:54 PM   #5
Tinker
Tinker's Avatar
Did you mark lift on the valves? Maybe you have a crazy cam that someone slapped some stock heads on. Unlikely but a thought.
Old 03-28-2012, 10:58 PM   #6
sandcanyon
sandcanyon's Avatar
You said the engine was laying on its side. It could have fallen over and cracked the head!
If you think you can do a thing or think you can't do a thing, you're right. Henry Ford
sandcanyon is offline   Reply With Quote
Old 03-28-2012, 11:09 PM   #7
Wily Kyote
Wily Kyote's Avatar
But, if they're stuck closed? Or in between.
Wily Kyote is offline   Reply With Quote
Old 03-29-2012, 10:50 AM   #8
bobj49f2
bobj49f2's Avatar
I didn't notice any unusual marks on the heads and the pistons look good other than having some carbon build up.
Old 03-29-2012, 08:29 PM   #9
flatjack9
flatjack9's Avatar
The valves can be stuck in almost any position and most definetly will not allow the engine to turn over. I've had engines with the valves so badly stuck that I actually broke a cam once trying to turn the engine.
Old 03-30-2012, 12:47 PM   #10
Mr 42
Mr 42's Avatar
Remove the camgear and see if it turns over.
Mr 42 is offline   Reply With Quote
Old 03-30-2012, 01:00 PM   #11
Mart
Mart's Avatar
Flatjack9 speaks wise words.
The two weeks with the penetrating oil helped. Removing 4 or 5 stuck valves will do the trick.
That's all there was to it.
Mart.
Old 03-30-2012, 02:17 PM   #12
bobj49f2
bobj49f2's Avatar
It turns over fine, it just didn't turn over when the heads were installed.
Another question, are there any differences between the EAB heads and the heads from a truck engine, 8HT(?)?. I'll need to find a either a matching head to two other kind that match.
Old 03-30-2012, 02:57 PM   #13
1952henry
1952henry's Avatar
EAB heads have higher compression than the 8RT.
I dig coal, which provides motivation for EVs.
1952henry is offline   Reply With Quote
Old 03-30-2012, 04:15 PM   #14
ford1
is there a flat piston head on with domed pistons?, put the head on with out a gasket and not tightened and turn engine over does the head lift when doing that, if so you need more head clearance over the pistons
Old 03-30-2012, 05:21 PM   #15
flatjack9
flatjack9's Avatar
The only way those heads would cause a problem is if they were excessively milled. Do as Ford1 has suggested. Also did the engine turn over without the heads on before or after you freed up the stuck valves?
Old 03-31-2012, 12:28 AM   #16
Mr 42
Mr 42's Avatar
OK i just reread your post, and you had a one or a couple of stuck pistons (or pistonring stuck to the cylinder).
Removing the heads was just a coincident.
I would remove the pistons and put in a new set of rings, think there is one or more piston with the rings stuck on them
Old 03-31-2012, 01:13 AM   #17
ford1
go back and reread his post, he said he could move the crank about 10 degrees, that is the amount of the movent between the rod and piston as the crank goes over top dead center, he said he could turn engine over with the head off, if so that eliminates stuck pistons , with the head off engine turns, that eliminates stuck valves prevening cam from turning, that leaves either a valve hitting the head or a piston hitting the head preventing movement, my guess is a piston hittting head,
Old 03-31-2012, 04:10 AM   #18
Mart
Mart's Avatar
If he said he could turn all the way around except for 10 degrees, in other words, 250 degrees, then one piston hitting the head may have been the problem.
We are all getting worked up about nothing.
The engine is turning, the valves are unstuck.
It's another one saved for a freshen up - lets all be happy at that.
Of course, for a sanity check, it wouldn't hurt to shove the heads back on and see if it still turns over.
The crack in the one head may have distorted the combustion chamber dome down on one cylinder - it's not likely, but possible.
Mart.
Old 03-31-2012, 12:39 PM   #19
ford1
Sorry Mart if i sounded a little worked up or overly excited, i was just trying to clarify the possible problem, head on engine wont turn, head off engine turns, that only leaves 2 possiblities, valve hitting the head and wedging or the piston hitting the head, i still think its the piston hitting
Old 03-31-2012, 01:32 PM   #20
Paul Selfe
Paul Selfe's Avatar
I think Mart has it, there may have been some water in the head. Froze while sitting, cracked the outside of the head , and pushed the chamber down against the top of the piston. Paul Selfe.
Paul Selfe is offline   Reply With Quote
