Old 03-05-2012, 06:31 PM   #1
32Gnu
32Gnu's Avatar
Default 32 3 window rear window
Is there supposed to be any supports holding the lower section of the wood/tray on the rear window?
I replaced the rear window wood, attached to the rear window strip along both sides.. everything appears to be tight, however I did remove the rear toll tray.. I am thinking I need to add some braces to connect to the rear trunk supports..
any thoughts?
32Gnu is offline   Reply With Quote
