#1 |
Is there a proper way to have the front license plate installed on an A/AA
#2 |
That is fine. If you desire, you can flip the license plate brackets over and mount the plate a little higher to aide in air flow through the radiator. The correct mounting as it was done at the factory is outline in the Judging Standards but again, do it however you like.
#3 |
That's one beautiful truck!
And Pepsi has always been my favorite.... |
#4 |
I mount mine high on the light bar unless I am going on tour and the weather is really warm in which case I take a spare REAR license bracket and mount it upside down sandwiched between the front bumper clamp backing plate and the front bumper bracket. The license plate is then displayed just above the bumper, kinda close to the front fender. I know... it looks like a Chevrolet (gasp!) but it aids in cooling when It's hot out and I don't want to remove my '29 Ohio plate.
#5 |
My dad's '30 coupe, which was Canadian, had an angle iron type middle segment of the headlight bar that contained holes for mounting the license plate. It looked to me like it had been welded in by someone, so when we restored the car I replaced it with a regular headlight bar. Then, I believe that I read somewhere that such a thing was actually factory issue. Now, I don't know what to believe. Does anyone know about this? I was so sure that the piece was non original that I tossed it out--perhaps one more entry in my dumb-things-I've-done list; it really worked well. You can sort of make it out in this photo.
![]() When I was a kid, I just wired mine to the bumper. Eventually, it would find the exact location it liked the best. Nowadays, since Michigan doesn't require front plates, I just leave it off. If someone wants to know what year it is, they can walk around to the back. ![]() Steve Last edited by steve s; 02-26-2012 at 09:51 AM. |
#6 | |
#7 | |
![]() Quote:
#8 | |
![]() Quote:
The buying public was the "lab". They used it on nearly 1/2 million cars so it was well tested! I wonder just how many they replaced.
http://www.abarnyard.com/ |
#9 | |
![]() Quote:
Steve |
#10 | |
![]() Quote:
Steve |
#11 |
hmm i run my plate the same as the good looking yellow truck at the top . never had a heating problem or a broken h/l bar . maybe im just lucky in that respect . every one in the "A" club here runs them like that .................. steve
V4f |
#12 |
Here is another picture. I like it mounted this way.
#13 |
#14 |
When I was having overheat problems I built a bumper mount for the front plate. The bottom of the plate rests about 3 inches above the top bumper.
#15 |
I've found that mounting it as Gary shows decreases the possibility of the plate rotating into the radiator and damaging the fins. But as Brent says, the JS show it both ways, depending on the year. And Ford factory photos are inconsistent with the JS.
Ray Horton, Portland, OR As you go through life, keep your eye on the donut, not the hole. ![]() |
