Old 06-27-2010, 01:08 PM   #1
Bobster
Bobster's Avatar
Default Wood clothes pins on the gas line
I posted this under another thread, but I am dying of curiosity. A neighbor said that he used to put clothes pins on his gas line (Flat head V8) to eliminate percolation and vapor lock. I don't see how it would work. What is the science? Would the wood pins act as a heat sink? Anybody have info on this? BW
BW in WV
Bobster is offline   Reply With Quote
Old 06-27-2010, 01:18 PM   #2
Colorado Greg
Colorado Greg's Avatar
Default Re: Wood clothes pins on the gas line
The clothes pins supposedly draw the heat from the gas line, thus cooling off the gas.
"Betsy doesn't leak oil - she just marks her spot"
Colorado Greg is offline   Reply With Quote
Old 06-27-2010, 01:19 PM   #3
George Miller
George Miller's Avatar
Clothes pins were used to hold on a wet rag.
George Miller is offline   Reply With Quote
Old 06-27-2010, 01:31 PM   #4
Jerry in Shasta
Jerry in Shasta's Avatar
Many Old Timers swear by the clothes pin fix. If I ever have the problem it's the first thing I'll try.
Regarding the oil spot. My "A", is just like my dog, it marking it's territory
Jerry in Shasta is offline   Reply With Quote
Old 06-27-2010, 01:53 PM   #5
Mustang
Mustang's Avatar
The deluxe version used cigarette package foil folded
over the gas line and held in place by the clothes pins.
Mustang is offline   Reply With Quote
Old 06-27-2010, 04:13 PM   #6
TK in LA
TK in LA's Avatar
My Dad, when I was growing up, swore my the clothes pins and tin foil method of heat dispersion. That was quite awhile back. Your results may very?
TK in LA is offline   Reply With Quote
Old 06-27-2010, 04:46 PM   #7
Vic in E-TN
BW:
There is a good thread from early June. Search "vapor lock". The title of the thread is "vapor lock for non believers". I wrote a long reply at the end of the thread. Clothes pins are a waste of time & effort. Vapor lock is real. I recently wrote an article for The Smoky Mountain Chapter newsletter - Rumble Seat Reviewer.
Vic
Vic
Vic in E-TN is offline   Reply With Quote
Old 06-27-2010, 07:58 PM   #8
Bobster
Bobster's Avatar
Went over to HAMB site to check out this question. Seems the wood pins work for some, but not others. The only function they could have would be as heat sinks - I thinks. BW
BW in WV
Old 06-27-2010, 10:40 PM   #9
Stan/MO.
Stan/MO.'s Avatar
See I told you guys about the clothes pins, but everybody made fun of me, like it never happened. Somebody must have thought it worked, or they would never have tried it. I'm really disappointed in you guys that KNOW EVERYTHING.
Stan/MO. is offline   Reply With Quote
Old 06-27-2010, 10:46 PM   #10
Bob Johnson
Bob Johnson's Avatar
If clothes pins work it is not because they are a heat sink. Wood is a very poor conductor of heat.
Bob
Bob Johnson is offline   Reply With Quote
Old 06-28-2010, 12:55 AM   #11
Tom Wesenberg
Tom Wesenberg's Avatar
I think George got it right. Clothes pins holding a wet rag would do a good job of cooling the fuel.
Old 06-28-2010, 06:21 AM   #12
Aerocraft
Aerocraft's Avatar
In the summer (when I was much younger), I used to wrap shop towels around the fuel pump and the line to the carb on the 8BA in my '50 Ford convertible and then pour water that I carried in the car on the rags. The evaporative cooling stopped the fuel from boiling and the engine would get enough fuel to run. It helped to pop the hood so that the safety latch was allowing the hood to be open slightly. I would have loved to have aluminum clothes pins which would have helped much more than wooden ones. Gar Williams
Aerocraft is offline   Reply With Quote
Old 06-28-2010, 09:01 AM   #13
MAG
MAG's Avatar
I had some success with clothes pins on a 51 Chev. that would vapor lock. But, so far they have not helped on my Model A to prevent Ethanol gasoline percolation.
I noticed the harder I work the luckier I get!
MAG is offline   Reply With Quote
Old 06-28-2010, 10:26 AM   #14
Stan/MO.
Stan/MO.'s Avatar
Thumbs up Re: Wood clothes pins on the gas line
AREOCRAFT.........Now there's an idea....Aluminum clothes pins, but put fins on them like a motorcycle cylinder.
" Hey ma' ya got any of them there finned aluminum clothes pins? My car's a vapor lockin' on me again."
Seriously, I was just teasing on my last post. I really appreciate all of you guys who are willing to share your knowledge with every one of us who are new to this hobby. I usually don't ask many questions, I just read the posts, and it never fails, someone will ask just what I want to know.
Thanks,
Stan
Old 06-28-2010, 11:23 AM   #15
Ron/IA
I have another theory about clothes pins on gas lines. While wrapping a piece of aluminum foil around the gas line making it look like a flap and holding it in place with clothes pins; that would be an effective heat sink. But another thing that occurs is the gas line will now vibrate at a different frequency. That vibration, in my opinion, contributes some to gas percolation. I think this is why sometimes clothes pins work, and sometimes they don't.
What do others say?
Ron/IA
1929 Fordor Steelback
Hawk A Model A Ford Club
http://hawkamodelaclub.org/
Ron/IA is offline   Reply With Quote
Old 06-28-2010, 11:29 AM   #16
Stinch
Stinch's Avatar
I've always thought the clothes pins prevented heat from getting to the fuel rather than pulling heat from the fuel. In other words, the clothes pin are an insulator. At least that's my take.
Rich
E30 68-B Cabriolet
Stinch is offline   Reply With Quote
Old 06-28-2010, 03:36 PM   #17
mass A man
mass A man's Avatar
Some cars came from the factory with a woven, black tubing over the engine compartments' fuel lines, called "lagging", to help prevent vapor-lock. Packard being one of them.-My 2 cents.
mass A man is offline   Reply With Quote
Old 06-28-2010, 04:34 PM   #18
Jason in TX
Jason in TX's Avatar
I was going to back up what stinch was saying.
People say the clothes pins draw the heat away, but I've been told to put as many clothes pins on the fuel line as possible, which would basically become insulation.
I think the wood in the clothes pins is insulating the fuel line, not pulling the heat away.
Drive it like you know how to fix it!
DMAFC / OILERS CC-MC
Jason in TX is offline   Reply With Quote
Old 06-28-2010, 08:04 PM   #19
Clem Clement
Clem Clement's Avatar
You guys completely missed the point: Clothes pins attract women's attention!! You have to take it from there yourself, period.
Clem, with a bizzilion copy righted stories to tell the ladies after they ask
Clem Clement is offline   Reply With Quote
Old 06-28-2010, 08:36 PM   #20
Doug in NJ
Doug in NJ's Avatar
If you attached a real heat sink to the fuel line, it would make the problem WORSE, since it would allow the fuel line to absorb more heat! Insulation is what you need...
Doug
My '31 S/W sedan project:http://31ford.dougbraun.com
My restoration diary: http://dougbraun.com/blog
Doug in NJ is offline   Reply With Quote
