Old 02-20-2012, 04:52 PM   #1
vince76
Default 3 Speed Trany Identification
I need help. Can anyone help me identifity this tranny? It was behind a 292 in a 59 Galaxie. The original tranny for the car was an automatic.
Any Help would be appreciated.
vince76 is offline   Reply With Quote
Old 02-20-2012, 10:14 PM   #2
Rowdy
Default Re: 3 Speed Trany Identification
That looks simular to these. I also have the empty cases for the transmissions. Those are not OD's on the back, just tail shaft housings. If you figure out which years these are for let me know. Thanks Rod
Do the RIGHT thing - Support the H.A.M.B. Alliance!!!!
Rowdy is offline   Reply With Quote
Old 02-20-2012, 10:38 PM   #3
Fordknut
They look like your run of the mill 3 speeds from about '55 or '56 to '62 when they came out with the fully synchronized trannys.
The best part about these trannys is that they have a larger countershaft than the earlier '49 to '53 or '54 trannys.
Pardon my being a bit vague as I'm not exactly sure when they changed the size of the countershaft. I have a '56 like this to which I mounted a '53 O.D. unit.
There are certain modifications that have to be made to the case in order to do that, however.
I just noticed the fine spline input shaft which dates this one to '58 thru '62.
Last edited by Fordknut; 02-20-2012 at 10:45 PM. Reason: Add comment about spline.
Fordknut is offline   Reply With Quote
