02-18-2012, 08:51 PM | #1 |
New Guy with problem
Just bought a 28 model A I can get the motor to run but have not got it all checked out yet as far as compression and such. But I think I may have a problem. I had the radiator cap off watching my coolant level while trying to start it. I think it backfired and coolant shout out the top of the radiator like a geyser. I am afraid to ask but what could that be.
02-18-2012, 09:00 PM | #2 |
Re: New Guy with problem
Could be just a blown head gasket. If your lucky
02-18-2012, 10:08 PM | #3 |
It ain't that hard to pull a head and look. Head gaskets are "relatively" cheap. As a matter of fact I've got a house full of cheap relatives.
02-18-2012, 10:20 PM | #4 |
do a compression check ,,,you will have bubbles in the radiator if the head gasket is gone
02-18-2012, 11:27 PM | #5 | |
Rob Kellogg Cazenovia, NY |
02-19-2012, 03:23 PM | #6 |
02-19-2012, 03:55 PM | #7 |
Makes good sense, but I still think y'oughta pull the head off and look where exhaust was passing across the coolant border. We like pictures too!
02-20-2012, 11:49 PM | #8 |
Remove the fan belt,idle engine & watch for bubbles in top tank of rad.If so,then combustion gases are likely leaking into cooling system.If rad is badly plugged,then water could be forced out cap or overflow.
02-21-2012, 10:31 AM | #9 |
The exact same thing happened to me the first time we attempted to fire up a new rebuild two motors ago. It turned out that the rebuilder had left a shop rag tucked in the cylinder head. The water pump did what it could to deal with it, but local overheating quickly caused a geyser out the radiator. Probably not your situation.
A straw to grasp at before tearing things apart is to try retorquing the head bolts. You didn't say if your motor is a recent rebuild or maybe head replacement, but if so there is a good chance retorquing will fix it--unless you persist in running it loose, which will truly blow the gasket. Steve |
