Old 06-26-2010, 09:26 PM   #1
sunoco67
Default unleaded gas in old cars???
We have an original 39 Chevrolet coupe and wonder what you guys use for gas (unleaded with additives?). The car appears to have an original motor that has not be updated to hardened valve seats..
sunoco67 is offline   Reply With Quote
Old 06-26-2010, 10:13 PM   #2
Russ/40
Russ/40's Avatar
Default Re: unleaded gas in old cars???
If your involved with Sunoco, I'd think you would be telling us what fuel to use.
Russ/40 is offline   Reply With Quote
Old 06-26-2010, 11:48 PM   #3
Bassman/NZ
Bassman/NZ's Avatar
A Chev in the Fordbarn?
Bassman/NZ is offline   Reply With Quote
Old 06-27-2010, 12:11 AM   #4
joel
joel's Avatar
It's not like you have much choice and it's the same cost to pull the head now as later. I'd drive it until you need a valve job. You might have more trouble with the gas eating fuel pump diaphams. I'd add some MMO to the tank to help lubricate the valves. Good Luck.
joel is offline   Reply With Quote
Old 06-27-2010, 08:46 AM   #5
53ash
53ash's Avatar
High octane with octane boost and lead replacement additive is what I run. Seems to keep the knocks down, and runs pretty good.
We carry: Amsoil Synthetic Lubrication products
53ash is offline   Reply With Quote
Old 06-27-2010, 10:52 AM   #6
Vic Piano
Vic Piano's Avatar
I don't know about GM but Ford, from 1932 to 1953 recommended using Amoco white gas which was the equivalent of unleaded gas. I've always run regular unleaded gas in our Flatheads with an occasional tank of mid grade.
Imagination is more important than knowledge.
Vic Piano is offline   Reply With Quote
Old 06-27-2010, 01:08 PM   #7
Steves46
Steves46's Avatar
Vuc, did you take the 53 Panel for a run yesterday? How did she do?
If it aint broke, don't fix it!
Steves46 is offline   Reply With Quote
Old 06-27-2010, 01:30 PM   #8
jdl
jdl's Avatar
Send a message via ICQ to jdl
I have always used 87 octane unleaded. some states have 85 octane. never a problem.
jdl is offline   Reply With Quote
Old 06-27-2010, 02:57 PM   #9
sunoco67
Thanks Guys I appreciate the information...
Old 06-27-2010, 04:52 PM   #10
Vic Piano
Vic Piano's Avatar
Steve, I drove the '53 Panel up to meet the guys for the Saturday Breakfast Club, the truck is still kicking under a load in first & second on acceleration and smoothes out in high. I was averaging between 55 and 60 mph with an occasional kick. I think I will still have to do some tweaking on the timing and maybe check out the vacuum advance... I’m thinking about pulling the distributor and putting the old one in to see if that makes any difference.
Vic
