Old 06-26-2010, 06:30 PM   #1
406Rich
406Rich's Avatar
Default Time for a change
i`m considering pulling the belly button motor out of my `37 coupe, I`ve located a 52/53 mercury flathead EAC Motor, with trans, what is this motor from can anybody give me a clue I`m new at flatheads...what to look for....?
406Rich is offline   Reply With Quote
Old 06-26-2010, 06:33 PM   #2
Brendan
Brendan's Avatar
Default Re: Time for a change
what is a belly button motor!
Brendan is offline   Reply With Quote
Old 06-26-2010, 06:34 PM   #3
Brian
Brian's Avatar
Good move!! Brian
Brian is online now   Reply With Quote
Old 06-26-2010, 06:36 PM   #4
406Rich
406Rich's Avatar
Chevy small block.....
Old 06-26-2010, 06:42 PM   #5
Brendan
Brendan's Avatar
oh, ok i was going to ask you if you wont to sell it, i already have two in my shop.
i think that would be a good idea to put the merc motor in!
Old 06-26-2010, 07:03 PM   #6
Frank The Plumber
thank you, you are a fine person.
Frank The Plumber is offline   Reply With Quote
Old 06-26-2010, 07:11 PM   #7
Kahuna
Kahuna's Avatar
Rich
Essentially what you have is the last of the flatheads for the US. The last Mercs were rated at 112-125 HP. If what you have is truly a Merc engine (many flatheads had parts interchanged), and it's in good shape, you've got a great engine.
Jim
Kahuna is offline   Reply With Quote
Old 06-26-2010, 07:28 PM   #8
denverslim
denverslim's Avatar
Oh, Man! There is a flathead god!.
Good man!...slim
denverslim is offline   Reply With Quote
Old 06-26-2010, 07:32 PM   #9
flatjack9
flatjack9's Avatar
I agree, good move. The only drawback to that engine is that it probably won't have hard seats in the exhaust.
Old 06-27-2010, 04:55 PM   #10
JM 35 Sedan
JM 35 Sedan's Avatar
Oh man!! That's good news , I'm sure that '37 will be much happier with a new FH heart transplant! Put that SBC back in a Chuby. I'm not that familiar with the Merc engines, but I would see if it has a four inch stroke crank, bore it a little over, and maybe install hardened valve seats. Keep us posted on the conversion process with some pics, etc. Good luck! JM
John
Old 06-27-2010, 05:40 PM   #11
jdl
jdl's Avatar
Send a message via ICQ to jdl
look for a 4" stroke, cam marked 1CM, 4 bolt mount for carb. good luck! glad your getting rid of the "belly button"
jdl is offline   Reply With Quote
Old 06-27-2010, 07:24 PM   #12
406Rich
406Rich's Avatar
Thanks guys, the engine is complete and together, with trans all parts there except gen/starter, been in a garage covered up for 30 years per the owner, are there any stampings on the block to verify.....? I`m trying to gather all the info I can so when I go to look it over I have a educated guess, I know that it is a crap shoot as far as being a cracked block..!
Old 06-27-2010, 07:29 PM   #13
PeteVS
PeteVS's Avatar
There's been a lot of talk about the engine. You didn't say too much about the transmission. Is it contemporary with the engine? I'm not too sure that a '49 and up transmission will work in the '37, especially if you want the traditional closed driveline.
Don't never get rid of nuthin!
PeteVS is offline   Reply With Quote
Old 06-27-2010, 07:34 PM   #14
406Rich
406Rich's Avatar
This is where it will get sticky, I`m going to keep the ford eight inch under it with open drive line, not sure yet on trans, still looking for options, any recomendations at this point....
Old 06-27-2010, 08:36 PM   #15
oldbugger
oldbugger's Avatar
If the trans is from a 52 merc it will be for the open driveshaft and side shift linkage good luck.
oldbugger is offline   Reply With Quote
Old 06-27-2010, 09:05 PM   #16
Mike B
Hey Rich, we must live close by, I saw that ad a few days ago myself.
Mike B is offline   Reply With Quote
Old 06-28-2010, 10:53 AM   #17
Django
Django's Avatar
Do you want an automatic or a stick? Modern or vintage?
Obsessed with all things 1936 Ford since birth... thanks Dad.
Django is offline   Reply With Quote
Old 06-28-2010, 11:11 AM   #18
TJ
TJ's Avatar
You can keep the 8 inch. Use a 48-50 F-1 three speed floor shift. It's open drive and will look like a stock trans with the floor shift. You will need to use the pickup bell housing also, as I think the Merc bellhousing is different. If the block has been sitting for a long time I would pull the heads and check for cracks. Hopefully it was not removed from a car due to a cracked block. I had exactly the same setup in my 37 coupe.
Old 06-28-2010, 11:17 AM   #19
FRANK PKNY
FRANK PKNY's Avatar
There is a flathead god after all!!
FRANK PKNY is offline   Reply With Quote
Old 06-28-2010, 11:42 AM   #20
Flathead Fever
Flathead Fever's Avatar
You have a bunch of guys here that will do what ever we can to help you get that Chevy boat anchor out of your Ford. Your car will never be normal, it must have emotional and self esteem issues. It's like somebody cutoff its penis at one time and now your considering putting back on.
Your going to loose half your power for twice the money but once you go Flathead you'll never go back. You will find that Flathead people are the nicest people on the planet. All my very best friends own flatheads, the billet Chevy guys just seem to be a little to bitchen for me. I’m serious, it’s like they are from two different planets.
Jerry
Flathead Fever is offline   Reply With Quote
