Old 05-09-2010, 06:42 AM   #1
George/Maine
George/Maine's Avatar
Default F1 steering problem
F1 steering problem, I just put a toyota ps box on, with a 14" steering wheel and and does,t seem to track very well.Someone before me put new front spring and was wonding if angle shim were left out ,or maybe put some in.Someone said more caster may help.I have only driven it about 20 miles ,has new tires.Any info
George/Maine is offline   Reply With Quote
Old 05-09-2010, 11:08 AM   #2
RMR&C
RMR&C's Avatar
Default Re: F1 steering problem
Junkyard box? If so, it probably has 100k+ miles on it.......may need a tune up. It needs some caster, 4-5 degrees IIRC. Also, how tight are the kingpins,etc?
That is a beautiful truck...hope you get it sorted out.
RMR&C is offline   Reply With Quote
