Old 01-10-2012, 06:37 PM   #1
46fordnut
46fordnut's Avatar
Default flatspot
i had my ford running today.. runs very nice just it hesitates when you go from dead stop.. points good carb rebuilt , new fuel pump. vac brake not working maybe? lots of power. it has a Flathead v8.
if rust were money i would be a billionaire!!
46fordnut is offline   Reply With Quote
Old 01-10-2012, 06:42 PM   #2
flatjack9
flatjack9's Avatar
Default Re: flatspot
Vacuum brake should have nothing to do with it. Could be that the accelerator pump is not giving a big enough shot.
Old 01-10-2012, 06:49 PM   #3
46fordnut
46fordnut's Avatar
it has always been like this from day one for me . does run at highway speed fine (65). flat spot is worse when engine is cold. forgot one thing ..i don't think the engine was ever rebuilt. at least i did not do that she is pretty rusty.
Old 01-10-2012, 07:13 PM   #4
ken ct
Check the small link that connects the throttle arm to the accel pump rod. The center hole in the throttle lever must not be a sloppy fit. Thats where you might get a hesitation when you give it gas from idle as depressing the gas pedal the first 1/4" does not start pushing the accel pump down till the slop is taken up. Where the bottom of the 2 pins go into the throttle lever.I have new ones if you need.If the hole is really worn bad like egg shapped you could braze it up and redrill it to the pin diam. must be a good fit. Not sloppy. ken ct.
ken ct is offline   Reply With Quote
Old 01-10-2012, 07:45 PM   #5
46fordnut
46fordnut's Avatar
ok..could tell me how much one of those are if i cant fix mine? forgot to tell you it is a holly 21-29 . i have the excel pump set on the middle hole. witch one for more fuel pumped in front or back hole?
