Old 01-06-2012, 12:34 PM   #1
Brendan
Brendan's Avatar
Default 36 pickup windshield seal
can a new gasket, or seal be installed with out taking out the windshield?
If it would have been a snake it would have bit ya!
i can't spell my way out of a paper bag!
Brendan is offline   Reply With Quote
Old 01-06-2012, 12:40 PM   #2
36tbird
Default Re: 36 pickup windshield seal
Do you mean that you want to crank it out and replace the outer seal? I am not sure about the clearance you would have across the top, if that is what you are proposing to do. If the current seal is old and crusty, you are going to have a heck of a time cleaning out the grooves where the new one will fit into.
36tbird is offline   Reply With Quote
Old 01-06-2012, 12:43 PM   #3
Brendan
Brendan's Avatar
that is what i would like to do,there is no seal there at all, it is gone!
Old 01-06-2012, 04:58 PM   #4
JM 35 Sedan
JM 35 Sedan's Avatar
Brendan, I just recently put an outer windshield gasket/seal in my '35 fordor. I had to take the windshield completely off and remove the old gasket that had only been on the WS frame of that car a few years. IT was a stiff piece of crap to begin with and was not doing a good job of sealing. I bought a Bob Drake gasket with contoured corners. Pulled the old gasket right out, cleaned up the groove/slot, and installed the new gasket in about 10 minutes using wooden popsicle sticks. I coated the new Drake gasket with baby powder before installing. I did all this on the kitchen table (with the wife's permission of course ) I could never have done it that easily with the windshield mounted in the car.
John
Old 01-06-2012, 05:00 PM   #5
36Bill
36Bill's Avatar
If the channel that the seal fits in is truly clean count yourself lucky, it is a bitch to clean. It's not easy to get a new seal in either, you will be time ahead to take it out and put it on a table so you can work around it. You run the risk of breaking the glass working the seal in with the windshield in the pickup.
Bill
36Bill is offline   Reply With Quote
