Old 01-02-2012, 03:07 PM   #1
Partsmandave
Default Model A wheel replacement
I would like to replace my stock model a wheels with some aftermarket steelies or artillery wheels . Will these mount to stock model a spindles without any adapters?
Dave
Partsmandave is offline   Reply With Quote
Old 01-02-2012, 03:22 PM   #2
V4F
V4F's Avatar
Default Re: Model A wheel replacement
call this guy . he built me some real nice 16" x 5/5 1/2 with like 4-5" wide wheels . been very happy ................ steve
http://www.earlywheel.com/about.html
V4f
V4F is offline   Reply With Quote
Old 01-02-2012, 05:37 PM   #3
Partsmandave
Steve.do they bolt right up to the model a spindles with the stock drums?
Thanks, for the reply!
Dave
Old 01-02-2012, 06:30 PM   #4
Paul's Garage
Ford pickup wheels until at least the year 2000 have the same bolt pattern, this would give you a host of various 15 and 16 wheels that I would think would fit and the salvage yards are full of them.
Paul's Garage is offline   Reply With Quote
Old 01-02-2012, 06:52 PM   #5
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Paul,
I "THINK" I read somewhere that to use those wheels, you had to add some kind of skinny ring to the hub for better support contact.
A friend told me you could use an old piston ring??
He could have been pulling my leg. Don't accept either statement as "GOSPEL," As I don't know everything either. Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 01-02-2012, 07:34 PM   #6
James Rogers
James Rogers's Avatar
I use 35 model 15" spokes on my racer and they don't need anything but bolted on.
Old 01-02-2012, 08:12 PM   #7
BILL WILLIAMSON
James,
I knew that, but I was refering to the later disc wheels, mounted to Model A hubs, and have heard of cracking the wheels without using some sort of ring??--Bill
Old 01-02-2012, 10:13 PM   #8
James Rogers
I have heard that also Bill, but have never had any experience in that direction.
Old 01-02-2012, 11:45 PM   #9
Geo. H
James, I suspect your racer wheels are 16" rather than 15"
Bill, the rule is, if the hub was meant for wire wheels you can use any Ford wire wheel with the same bolt pattern. If the hub was meant for disk wheels you can use any Ford disk wheel with the same bolt pattern. If you use disk wheels on a hub designed for wire wheels, you'll need an adapter. If you use wire wheels on a hub designed for disks, you'll need an adapter.
Geo. H is offline   Reply With Quote
Old 01-03-2012, 12:49 AM   #10
hardtimes
hardtimes's Avatar
Yup, Geo has 'it' right. And, my '35 wires(40 spoke kelseys) are 16".
hardtimes is offline   Reply With Quote
Old 01-03-2012, 01:08 AM   #11
BILL WILLIAMSON
Originally Posted by james rogers View Post
i have heard that also bill, but have never had any experience in that direction.
i think you have to use a shouldered ring when putting '35 wire wheels on hydraulic drums.
Old 01-03-2012, 07:13 AM   #12
James Rogers
You guys are correct. Sometimes I need to just look at something before I type.
