Old 01-02-2012, 09:16 AM   #1
metalho
metalho's Avatar
Default Temp controls
This is what Ill be up to today, I dont see the steering column supported in this pic. Do you think it should be396713_247208925347581_100001754276005_595330_1855025793_n.jpg
metalho is offline   Reply With Quote
Old 01-02-2012, 10:34 AM   #2
Jim Parker Toronto
Jim Parker Toronto's Avatar
Default Re: Temp controls
Yes, and make sure there is a nut to hold the steering wheel on! (don't ask me how I know this!) A makeshift seat belt is also a good idea.
Jim Parker Toronto is offline   Reply With Quote
Old 01-02-2012, 10:51 AM   #3
metalho
metalho's Avatar
Thanks Jim, Im on it
Old 01-02-2012, 05:25 PM   #4
RTC1930
RTC1930's Avatar
LOL, that car looks familiar, and yes I did add a steering column bracket to it before taking it on the road. Even with the support it had a little wiggle that i didn't like. I had to disconnect the fuel control rod cause every wiggle effected the throttle. I have some more pics of it if that helps. However I did not do a seat belt because I wanted to make sure I could bail if needed and I wore a motorcycle helmet instead. Although I probably would have gone down with my ship so to say. Just don't whip around any corners and you will be fine. The only down side to driving the car like that is I'm now obsessed with finding a roadster next because how great it felt going down the road open like that (its currently a 4 door sedan).
Good luck and have fun!
Bob NJ
"Fix what's broken"
RTC1930 is offline   Reply With Quote
Old 01-02-2012, 06:21 PM   #5
Paul from Maine
Paul from Maine's Avatar
I thought the "nut" holds on to the steering wheel!
Paul from Maine is offline   Reply With Quote
