Old 12-31-2011, 06:46 PM   #1
PeteVS
PeteVS's Avatar
Default AV8 alternate to using a '32 K member?
What are some ways to mount a traditional Early V8 drive line in a Model A without using a '32 K member? I know an F1 crossmember works out well, but are there other choices? Got photos? Thanks!!
Don't never get rid of nuthin!
PeteVS is offline   Reply With Quote
Old 12-31-2011, 07:21 PM   #2
296 V8
Default Re: AV8 alternate to using a '32 K member?
Steel is traditional …. make something. Wouldn’t it be nice to remove the trans without taking the motor lose anyway?
296 V8 is offline   Reply With Quote
Old 12-31-2011, 08:10 PM   #3
Barry WNY
later X member
Barry WNY is offline   Reply With Quote
Old 12-31-2011, 08:12 PM   #4
Mart
Mart's Avatar
Not using the 32 k-member is a good idea if you want to use anything other than an early Ford 3-speed. If a 5 speed is on the cards the K-member needs so much cutting it's not worth using.
Mart.
Old 12-31-2011, 11:02 PM   #5
Bassman/NZ
Bassman/NZ's Avatar
This was my solution.
Bassman/NZ is offline   Reply With Quote
Old 01-01-2012, 12:52 AM   #6
PeteVS
PeteVS's Avatar
Bassman: Is your picture looking towards the front of the car or towards the rear??
Old 01-01-2012, 01:26 AM   #7
Bassman/NZ
Bassman/NZ's Avatar
Hi Pete,
looking toward the rear.
Couple more.
Old 01-01-2012, 06:17 AM   #8
Barry WNY
Hi Bassman, just wondering, was it not possable to make a mount on the other side for the park brake? I narrowed the body to follow the frame rails so you have more room down there than I do, just wondering if it was still comfortable like that. I thought making up the park brake was more of a pain than making pedal & bellcrank mounting.
Old 01-01-2012, 04:52 PM   #9
Bassman/NZ
Bassman/NZ's Avatar
I made the bellcrank set up in one of the above pics because I'm a miserable sod and only use what's cheap or free. The pedal assy was free so I had to work around it. I had a pair of Speedway rear spring hanger brackets lying around, so I used that and it's teflon bushings as the basis of the crank. Works fine after some tweaking. I better add I'm using the V8 park brake cable system.
Old 01-01-2012, 06:43 PM   #10
Bob/Ohio
Bob/Ohio's Avatar
Pete,
Look in my "Profile" and I have a couple of pics of my frame. I left the stock "A" cross member and added the "x" from pieces from a 48 frame. Works for me.
Bob
Bob/Ohio is offline   Reply With Quote
Old 01-01-2012, 06:50 PM   #11
Bassman/NZ
Bassman/NZ's Avatar
Originally Posted by Bob/Ohio View Post
Pete,
Bob
I wanted to use the stock A crossmember too, and made a couple of different trans mounts, but they were not to my liking, so I built the one you see. If I was to do it again I would persevere with the stock crossmember.
Old 01-01-2012, 08:31 PM   #12
columbiA
In ,64 I put a C59A in a A chassie by useing a 37 X member.I had to notch & lower the centre section to have the right height for the ball socket for the lengthened radius rods.I also used stock steering by welding on a steering mounting section from a junk frame & then cutting out part of original frame in order to move steering box over to clear V8.
columbiA is offline   Reply With Quote
Old 01-01-2012, 08:37 PM   #13
PeteVS
PeteVS's Avatar
Thanks guys! When spring comes, I'm gonna have to drag out my "mock up" frame (the one in my avatar,) A rear, '48 pedals, trans case and a trans mount to see where everything is. Then, I'll go from there.
Old 01-02-2012, 05:37 AM   #14
bobbooth
bobbooth's Avatar
you can Use a 33/34 "K" member which will also allow you to use the wishbone you just have to do a little fab work to both the "K" member and the mounte for the 3 speed btu simple really.
cut the rails of the "K"member to allow them to taper up to the "A"frame
weld them up
bobbooth is offline   Reply With Quote
Old 01-02-2012, 09:33 AM   #15
hotrodfreak
hotrodfreak's Avatar
I like the model 40 sliced X member best, looks good with real Henry parts.
hotrodfreak is offline   Reply With Quote
Old 01-02-2012, 08:47 PM   #16
Bob/Ohio
Bob/Ohio's Avatar
Posted a few more pics today of my AV8 project. You can see more of the rear portion of my "X", which I tied into the frame at the point I cut the "Z" in it.
Bob
Old 01-15-2012, 04:00 PM   #17
CT AV8
CT AV8's Avatar
Pete,
What did you end up doing with the '32 style AV8 K-member you fabricated?
Not going with a flathead on your project?
CT AV8 is offline   Reply With Quote
Old 01-15-2012, 08:35 PM   #18
PeteVS
PeteVS's Avatar
Originally Posted by CT AV8 View Post
Pete,
The AV8 project I was working on got put on back burner this year due to working on my brother's '32. Then, he expressed interest in doing another A and I was looking for options to avoid cutting up the original K member that I had bought a while ago and built the new K to avoid cutting it up. (I also have a fondness for motors painted up like '52 flat heads. I have one in my fiberglass bodied coupe.)
Old 01-16-2012, 11:10 AM   #19
CT AV8
CT AV8's Avatar
Pete-
The other thing to consider if your using an early Ford V-8, without stating the obvious, is the pedal selection. That goes hand in hand with k/member, trans mount. We used a set of '32 pedals as per Vern's B-T roadster and it was a nice fit, but they're getting hard to find and $. I know some guys like to use a '39 pedal set up, but you loose most of the driver side part of the k-member going that way.
