Old 12-31-2011, 01:31 PM   #1
flathead47
flathead47's Avatar
Default 1984-87 f150 o/d trans in the torquetube
Looking for information , adapter drawing , install pictures that will connect the 1984-87 Ford f150 aluminium toploader 4 speed manual overdrive transmission to the early Ford torquetube.
Planning to install into 35-36 Ford chassis.
4th gear is overdrive , the shifter assembly is on top of the the tranny where the cast toploader inspection plate is.
The shifter will come thru the floor very close the the original 35 -36 ford 3 speed location. The shifter is very similar to the hard to find CJ jeep shifter assembly that was installed as per the street rodder article several years ago. .......... Thanks
flathead47 is offline   Reply With Quote
Old 12-31-2011, 01:57 PM   #2
Teich
Default Re: 1984-87 f150 o/d trans in the torquetube
check with miss victoria will make what you describe and it works very nice. search form for overdrive and you will find his post. Have one in my 48 love it! Laurie
Teich is offline   Reply With Quote
