Old 12-24-2011, 04:48 PM   #1
Rainmaker Ron
Rainmaker Ron's Avatar
Default Night vision
I am still driving the pick up I finished rebuilding in October. Every few years here in the midwestwe have a mild winter that hangs on until the new year. This little truck is fun to drive but not after dark. My shop is 3 miles from home and it is dark by 5:00 P.M. most evenings when I leave. Driving home, the flat glass reflects so many lights that it is confusing to drive. When it is warmer I tilt the windshield and the reflection is not a problem. I hate to put the truck away as long as there is no salt on the roads, does any one have a trick to eliminate the reflection problem?
Rainmaker Ron
Rainmaker Ron is offline   Reply With Quote
Old 12-24-2011, 05:03 PM   #2
Great Lakes Greg
Great Lakes Greg's Avatar
Default Re: Night vision
Passenger cars have pull down shades in the back window for just this dillema. Seems like trucks would also have this feature regardless of being a "no frills" vehicle. Lebaron can supply the shade with the spring loaded roller for about $30. Brackets are available through any aftermarket supplier. Even if this wasn't offered on pickups, I don't think you could go wrong installing one.
Great Lakes Greg is offline   Reply With Quote
Old 12-24-2011, 05:39 PM   #3
LukeDahlinger
Only problem with this is there is no real way to mount the curtain as there's no wood around the back window like you'd find in a Coupe or Sedan.
Wanted- Feb. 1931 Parts Price List
www.vintagefordfacts.blogspot.com
LukeDahlinger is offline   Reply With Quote
Old 12-24-2011, 07:59 PM   #4
31 Pickup
I used to know a truck driver that had a small blue light mounted near the bottom of the windsheild
He said it was to cut down the headlight glare and reflections of the dash lights on the windows
It was a small 'cone' shaped light (kind of like a motorcycle turn signal)
Maybe a dash light (like the one under the dash rail) with a colored bulb or lens
31 Pickup is offline   Reply With Quote
Old 12-24-2011, 08:09 PM   #5
Clydes 31 P/U
Ron, I had eye surgery years ago and now the glare from oncoming lights is horrible for me I started wearing my polarized yellow shooting glasses and that really cut the glare for me
Clydes 31 P/U is offline   Reply With Quote
Old 12-24-2011, 09:51 PM   #6
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Use it to advantage. At night I park at the 99 cent store to do girl watching. I can see them coming from any direction. It's like having mirrors everywhere! I've sorta got used to it over a period of time. I think it helps me to be a more careful driver. Someone's Polaroid glasses suggestion sounds like a good idea. Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 12-24-2011, 10:41 PM   #7
Aerocraft
Aerocraft's Avatar
Tilting the windshield has always worked for me with my '30 Coupe. It only takes a small angle to deflect the reflections. The colder weather here in the Chicago area does make it a bit uncomfortable but I dress warmly, put a blanket over my legs, and grin and bear it. The Autolight manifold heater does help some but it can still be quite cold. I simply love the opportunity that we have had this year to drive so deeply into the winter without concern about salty roads. The hammer will fall soon........... Gar Williams
Aerocraft is offline   Reply With Quote
Old 12-24-2011, 11:13 PM   #8
Rainmaker Ron
The blue light and the polaroid glasses are worth a try. Thanks for the creative thinking.
Most folks do not know the purpose of the rear shade, it is widely thought to be designed to conceal some hanky pank.
Rainmaker Ron
Old 12-25-2011, 09:06 AM   #9
Lew
I have not tried this, but think it might work. There are magnetic curtin rod brackets available (with the rod). I would think that would work, and it would be easily removed if desired. A curtin could be made of cloth, or maybe some kind of anti-glare window coating.
Lew is offline   Reply With Quote
Old 12-25-2011, 09:53 AM   #10
Tom Wesenberg
Tom Wesenberg's Avatar
I wonder if one of those window screens that you apply to the glass would work. This is the type with a lot of small holes so you can see out, but it's hard to see in. These often depict some graphic such as the Conferate flag, FORD in script, etc.
Old 12-25-2011, 09:58 AM   #11
V4F
V4F's Avatar
tint the back window .............. steve
V4f
V4F is offline   Reply With Quote
Old 12-25-2011, 10:12 AM   #12
RcT
Tear some rags into stips and stuff them in the dash rail from the bottom to block the air movement. Then open the windshield slightly to an angle that works for you. I'm guessing this would at least, cut down on the cold air to your legs.
RcT is offline   Reply With Quote
Old 12-25-2011, 12:10 PM   #13
Aerocraft
Aerocraft's Avatar
The rear curtain will stop most of the reflections but I worry about getting hit from the rear, especially at night, so I am very reluctant to pull it down. Gar Williams
Old 12-25-2011, 01:08 PM   #14
JD Miller
How will the position of the rear window curtain make any difference in getting hit from the rear? If some idiot is going to hit you from the rear the position of the rear curtain is certainly not going to stop that from happening. I always pull the rear curtain down when driving at night. As mentioned, it cuts down on windshield glare, yet allows enough light through to be able to tell if there is a car following.
JD Miller is offline   Reply With Quote
Old 12-25-2011, 03:19 PM   #15
Jordan
Jordan's Avatar
if it's a pickup cab, there's no interior really to speak of besides the seat & kick panels. That leaves a lot of exposed metal. take an old shop rag, and fold it over sewing magnets into one end. simply put the towel over the back window at night using the magnets to hold it up, and take it down when you get home. This could probably be used on any model a since all the window trim is metal.
Cowtown A's
Jordan is offline   Reply With Quote
Old 12-25-2011, 07:50 PM   #16
Paul from Maine
Paul from Maine's Avatar
Rainmaker Ron
I solved my night glare problem by pushing out the windshield a few degrees and sealing up the gaps with duct tape the same color as the paint. Looked like I was driving a '31 Town Sedan instead of a '29. When spring came, I peeled off the duct tape. I bet that blue, wide masking tape would work if you are worried about your paint.
Paul from Maine is offline   Reply With Quote
