Old 12-12-2011, 02:49 AM   #1
Boscobill
Boscobill's Avatar
Default 37 Flathead V8 bike project
Hi, new guy to this forum, Always loved flatties and bikes so this project came together, here is a link to the build photos....
http://www.vinmoto.org/gallery/v/Vin...sBill/1937+v8/
Boscobill is offline   Reply With Quote
Old 12-12-2011, 03:00 AM   #2
ford38v8
ford38v8's Avatar
Default Re: 37 Flathead V8 bike project
Bill, that's a sweet ride!
Alan
Old 12-12-2011, 10:32 AM   #3
Ralph Moore
Ralph Moore's Avatar
That puts the Boss Hog to shame! I would have loved to have seen one of those at Sturgis, I'm sure it would draw the biggest crowd there.
Ralph Moore is offline   Reply With Quote
Old 12-12-2011, 10:42 AM   #4
Ol' Ron
Ol' Ron's Avatar
Very interesting torqure converter, just love things like that.
Old 12-12-2011, 10:43 AM   #5
Gumpy
Gumpy's Avatar
wicked lookin bike love those flat powered!!
"I believe God is managing affairs and that He doesn't need any advice from me. With God in Charge, I believe everything will work out for the best in the end. So what is there to worry about". Quote by Henry Ford
Gumpy is offline   Reply With Quote
Old 12-12-2011, 11:20 AM   #6
Junknshit
Banned
Like Ol'Ron, I just love things like that. Also love people like Boscobill. They don't run into problems, they run into opportunities. The opportunity to prove that it can be done and that they can do it. This build makes some of my problems/opportunities seem pretty trivial.
Way to go Bill!!!
Junknshit is offline   Reply With Quote
Old 12-12-2011, 11:31 AM   #7
Russ/40
Russ/40's Avatar
Amazing engineering! Where there is the will there is the way. Especially with your talent.
Russ/40 is offline   Reply With Quote
Old 12-12-2011, 11:40 AM   #8
36 flathead
Very nice, how about more info on torque converter.
36 flathead is offline   Reply With Quote
Old 12-12-2011, 12:52 PM   #9
roseville carl
roseville carl's Avatar
Wow thats using your head for something other than a hat rack!! Nice job!
roseville carl is offline   Reply With Quote
Old 12-12-2011, 01:25 PM   #10
Boscobill
Boscobill's Avatar
Gee, Thanks guys, i build cycles to ride, not really to show or sell. I had always dreamed of having an Indian 4, but realized i'm getting older, and the chances of that ever coming about were slim. The flathead V8 was the only substitute. Most of the ones i saw online used the extremely hard to find V8 60s, or were monsterously misproportioned. They also all were using a single speed right angle gearbox and stock clutch, and were said to be a bit impractical for a daily rider, and a handful to start out, especially uphill. My soulution was to use the torque convertor and front cover/pump from a Dodge omni. I used a 12" saw blade to adapt it to the V8 flywheel,
utilizing the original pressure plate bolt holes. Also used the Dodge's front clutch after cutting the planetary hub off of it. I shortened the drive shell and welded it to a stub pto shaft, driving a short chain turning a goldwing 1500 shaft drive rear end. The case was made from 9"x1/4" steel tube counterbored for the pump/cover and rear bearing cover. Using cardboard templates, i laid out the steel bellhousing and welded it up after truing. I routed the pump output to the converter with a relief valve from a yamaha, and ran pressure to the clutch via an external ball valve ,allowing for neutral. The stall speed matches the V8 well, smooth solid take offs, and acceleration up to 95+. The old flatty is being fed by a side-draft S&S Super G, and runs smooth and strong. It has proven to be a hassle free daily rider, and a true joy to ride!
Old 12-12-2011, 02:06 PM   #11
Old Henry
Old Henry's Avatar
I'm impressed! I am very impressed! You are some grease monkey. I'd love to see it in person, see you ride it and hear it in real life. You are amazing!
Old 12-12-2011, 04:38 PM   #12
Fe26
I'm very impressed, engineering and imagination, congratulations on a superb effort.
Fe26 is offline   Reply With Quote
Old 06-07-2012, 09:37 PM   #13
Boscobill
Boscobill's Avatar
Since the last time i posted , have upgraded to a lock-up style converter and built a gear drive to replace the chain from trans to driveshaft and committed to a color....Also added a GM hei distributor as an ignition trigger, driven from the crank by a small timing belt, as this makes adjusting the timing a breeze, with centrifigal advance as well as the vacuum advance. The timing cover distributor still is used for spark distribution an the points are still there as a backup if the hei module fails.....
Old 06-08-2012, 11:07 AM   #14
richard crow
boscobill you are a very taltened man
richard crow is offline   Reply With Quote
Old 06-08-2012, 11:52 AM   #15
TomT/Williamsburg
TomT/Williamsburg's Avatar
This bike is really sweet - have you posted this over on the HAMB, BTW? I think the folks there would get a real kick out of this build .... way to go!
TomT/Williamsburg is offline   Reply With Quote
Old 06-08-2012, 12:28 PM   #16
Butch11443
Butch11443's Avatar
Very nice! Something like this really interests me. Would love to see it someday and meet you.
Butch
Butch11443 is offline   Reply With Quote
Old 06-08-2012, 01:40 PM   #17
bk53
Hats off to Boscobel Bill and the Flathead V8 Bike project. it deserves a place of honor among the other great bikes to come out of Wisconsin, or anywhere else for that matter.
bk53 is offline   Reply With Quote
Old 06-08-2012, 05:24 PM   #18
Bassman/NZ
Bassman/NZ's Avatar
Wow! Amazing. That's the best flattie bike I've ever seen. How does it handle and steer?
Bassman/NZ is offline   Reply With Quote
Old 06-08-2012, 05:39 PM   #19
felix37
felix37's Avatar
Nice!!! I like it!
felix37 is offline   Reply With Quote
Old 06-08-2012, 06:26 PM   #20
36tbird
Sent you a PM as part of the great promote v-8 60 project. Lou
36tbird is offline   Reply With Quote
