#1 |
What's the secret to sealing a oil return tube? Can't get mine to stop seeping. I am using new cork gaskets and copper washers.
#2 |
Could it be leaking where the tube joins the dome shape end cap? I think the seam is soldered or brazed, might be a split there.
#3 |
exactly wear is the leak ? the tube goes in the pan . hmmmmm .. steve
V4f |
#4 |
I had the same problem and tried the cork / copper gasket approach to seal the leak. Still leaked at the lower end. Black silicone solved the problem. Not Henry Ford, but it works for me. BW
BW in WV |
#5 |
Mine is leaking on the top side where the cork gasket is.
#6 |
#7 |
are you sure its the pan ?? wash clean , start motor & watch it untill the leak shows up ............. steve
V4f |
